Just got around to doing some general maintenance on the router recently and found that I had messed up on the Y-Axis design, by not leaving enough space to access the grease fitting:
I don't really want to start disassembling things to get temporary access, as everything's lined up/trammed nicely now - so was wondering if anyone knew of a way so that I can grease this in it's installed position? Maybe some sort of ~10mm long M6x1 male to female extension which I could install temporarily in-between the two so that the fitting clears the Y axis base plate enough to get the grease gun onto it?
Cheers,
Raz
