    Hey Guys.
    So a few things..
    I noticed my machine had extrusions which where double mounted to make them far taller than needs be.
    So today i have taken the extensions off, leaving me with a frame i cant attach to the MDF board.
    I presume Sliding nuts / t slots would be fine if i made approximately 5 holes on either side of the 1 meter x 1 meter board?
    So having looked at the various types of nuts, i cant seem to work out the extrusion type/series.
    The rails i have are 20mm x 80mm.
    How can you tell the major differences1?
    1
    Sorry crystal ball is still broke. How about some pics.
    Yeah that would have been good lol.
    Attached Click image for larger version.
    Any ideas? Also, right now the bottom frame is mounted on MDF. I want to swap this to at least aluminium or steel struts, how would I go about doing that?
    Sent from my SM-N930F using Tapatalk
    Think its v-slot linear rail
    See http://ooznest.co.uk/Linear-Rails
    They have all sorts of brackets & fixings, hopefully there should be some of use
    Quote Originally Posted by Greeny View Post
    Wow thanks Greeny, The prices look great too!
    Now for the structural engineering bit.
    Should i go for a steel struts or Aluminum struts like:
    Or Others (if you know a better formation).
    I am thinking by going for struts, i can extend to 1500mm and just add more struts and extend the rails.
    No probs :-)
    My preference would be as shown in the picture, with a base of birch plywood(or other material) bolted to the cross members to add extra rigidity and act as a support for spoilboard/piece holding.
    Hopefully some others with more experience (ie nearly everyone here!) will offer their advice.
  1. CNC Router Parts.com rails, V bearings and rails blocks and more
    By adamh in forum Classified Ads, Buy, Sell & Swap
    Last Post: 25-02-2017, 01:31 AM
  2. BUILD LOG: My first build, Alu Extrusions
    By kjetor in forum DIY Router Build Logs
    Last Post: 28-10-2015, 12:15 PM
  3. where do you get the v groove channel extrusions from
    By nobby in forum Marketplace Discussion
    Last Post: 29-04-2014, 04:19 PM
  4. Steppers, Series, Parallel
    By Ricardoco in forum Stepper & Servo Motors
    Last Post: 12-01-2013, 08:28 PM
  5. Mitsubishi FR-D700 Series VFD
    By acollins in forum Motor Drivers & Controllers
    Last Post: 31-05-2012, 07:24 AM
