Page 2 of 2 FirstFirst 12
    Lives in Plymouth, United Kingdom. Last Activity: 10 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Posh way is to take out the clamp screw and tap the clearance hole a size larger. You can then use a jack screw down the hole to controllably open the slot. On the other hand, I have a chunky screwdriver that has one of those red arrows painted on the tip; inserted carefully you can open the slot enough without unduly loading the gantry and the marks will be in the slot and won't show...
    So an update. Play in mount issue sorted. I managed to get it out. Un bolt the holder from the assembly, and get to the bolts the other side, one of the 2 was totally loose. Problem solved. 👍👌 - best thing. No wedges 😂😂
    Sent from my SM-N930F using Tapatalk
  1. WANTED: WANTED - CNC Milling Machine, complete plug and play solution
    By Dangle_kt in forum Items Wanted
    Last Post: 30-10-2016, 01:31 PM
  2. play in bk1204 end bearing blocks
    By dazza in forum Machine Discussion
    Last Post: 30-07-2014, 09:28 PM
  3. Anyone play World Of Tanks ?
    By Fivetide in forum General Discussion
    Last Post: 10-09-2012, 11:46 AM
  4. Should my Z axis have a little play in it?
    By Philly in forum Gantry/Router Machines & Building
    Last Post: 29-04-2011, 04:28 AM
  5. Play in linear bearings
    By leadinglights in forum Rails, Guideways & Bearings
    Last Post: 01-05-2010, 05:01 PM
