  1. #4
    Lives in Marple Stockport, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    My only complaint with my cheap (around £2 each) inductive sensors is that mine don't seem to have any significant separation between on and off points. Not generally a problem, except that if I home all three axes and then jog in X or Y, the vibration tends to trip the Z limit switch as the sensor is just at its trigger point. Difficult fix, though - jog the Z down a millimetre or so first. Repeatability seems to be spot on, at least for my woodworking purposes. Must be our cold northern climate that means they work better here?
    Neale You should be able to set the home position to about 1mm off the switch. Do you have the software set to back off the switch after it is triggered?
  1. Spindle position sensor
    By GeoffV in forum Motor Drivers & Controllers
    Last Post: 23-03-2014, 10:00 PM
  2. Z AXIS, big tex blue screen and auto tool sensor Problems
    By Tomnewry in forum Artsoft Mach (3 & 4)
    Last Post: 01-01-2014, 09:01 PM
  3. How to Wire this Sensor
    Last Post: 26-11-2013, 05:09 PM
  4. Proximity sensor help required
    By plasticsales in forum General Electronics
    Last Post: 21-08-2013, 07:02 PM
  5. Mdx-40 (with zcl-40) Y sensor bar. Help!
    By Rastamonk77 in forum Milling Machines, Builds & Conversions
    Last Post: 12-02-2013, 09:44 PM
