Thread: Video on different sensor types
That sounds like just what's needed - thanks very much for the pointer. I read manuals carefully when setting up something like this but if you don't know that a feature is present, it's easy to miss while you are looking for something else. Like the M31 macro (or at least the code inside it), it's a CSLabs extension that doesn't exist in vanilla Mach3 and they're not easy to spot.
Might go out to the garage shortly and give that a try. I did some quick tests last night looking at Z axis homing repeatability with my inductive prox switches. Doing a "Ref Z" followed by an auto tool height zero on a touchplate, I was seeing around 10micron variation. However, I had not clamped the block down (it was sitting on the wood blank I was about to machine and I know that there's a tiny amount of give there) and I have found that using a tool like that does leave a microscopic dent in the touchplate surface so that the zero point gradually sinks. We are talking microsteps here, though - it's really not significant. I'll try with a clamped-in-place dial gauge and see what I get. And in this context, 10micron ain't worth worrying about anyway. But in the interests of science (and as long as it doesn't get in the way of doing the job)...
02-03-2017 #2
Yes there's quite few "hidden" aspects to the cslabs controllers which are good but not very well or at all documented. Like fact you can talk directly to controller using modbus and bypass mach3, which is exactly what the G31 macros does. Gives that bit more control and faster reactions times for I/O.!! . .. So long as you speak the lingo so to speak.!!!
Spindle position sensor
By GeoffV in forum Motor Drivers & ControllersReplies: 3Last Post: 23-03-2014, 10:00 PM -
Z AXIS, big tex blue screen and auto tool sensor Problems
By Tomnewry in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 01-01-2014, 09:01 PM -
How to Wire this Sensor
By manofgresley in forum General ElectronicsReplies: 1Last Post: 26-11-2013, 05:09 PM -
Proximity sensor help required
By plasticsales in forum General ElectronicsReplies: 12Last Post: 21-08-2013, 07:02 PM -
Mdx-40 (with zcl-40) Y sensor bar. Help!
By Rastamonk77 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 12-02-2013, 09:44 PM
