    That sounds like just what's needed - thanks very much for the pointer. I read manuals carefully when setting up something like this but if you don't know that a feature is present, it's easy to miss while you are looking for something else. Like the M31 macro (or at least the code inside it), it's a CSLabs extension that doesn't exist in vanilla Mach3 and they're not easy to spot.
    Yes there's quite few "hidden" aspects to the cslabs controllers which are good but not very well or at all documented. Like fact you can talk directly to controller using modbus and bypass mach3, which is exactly what the G31 macros does. Gives that bit more control and faster reactions times for I/O.!! . .. So long as you speak the lingo so to speak.!!!
  1. Spindle position sensor
    By GeoffV in forum Motor Drivers & Controllers
    Last Post: 23-03-2014, 10:00 PM
  2. Z AXIS, big tex blue screen and auto tool sensor Problems
    By Tomnewry in forum Artsoft Mach (3 & 4)
    Last Post: 01-01-2014, 09:01 PM
  3. How to Wire this Sensor
    Last Post: 26-11-2013, 05:09 PM
  4. Proximity sensor help required
    By plasticsales in forum General Electronics
    Last Post: 21-08-2013, 07:02 PM
  5. Mdx-40 (with zcl-40) Y sensor bar. Help!
    By Rastamonk77 in forum Milling Machines, Builds & Conversions
    Last Post: 12-02-2013, 09:44 PM
