    Continuing with my Fehlmann mill-drill conversion, I have been sorting out what might be referred to as the W axis, that is the coarse positioning of the milling head. The machine as originally designed uses a microswitches and stops to obtain three user settable positions of the head. This vid from a couple of years ago shows the head and stop arrangement
    I've had this working with the stops but they only appear to be repeatable to about 0.1mm - which will mean tool height setting every time the head is moved.
    I was intrigued to find that Fehlmann continued developing my machine until about 2011 with the later Picomax 54 and 55 being almost identical but with CNC control of the W axis. Seen here:
    The Picomax 54 uses the same motor as in my P50 but has a rotary encoder on the end of the pinion shaft - I'm sure Fehmann's rack and pinions are very accurate but it doesn't seem like the greatest way of obtaining positional info. The motor is controlled by a VFD and somehow this controls the position of milling head using info from the encoder.
    I think that the Picomax 55 is doing the same thing but with a glass scale - I'll check with Fehlmann.
    Can anyone illuminate me about how it is possible to use an induction motor, inverter and encoder to obtain absolute position? I see this clever chap manages to achieve it:
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    This is a vid by Andy Pugh He is on the LinuxCnc forum and I think he is also a developer.
    Thanks Clive, I'll drop him a line.
    David
  1. VFD 220v single phase to 380v three phase.
    By Richard in forum General Discussion
    Last Post: 14-12-2020, 11:19 PM
  2. FOR SALE: For sale: 5 induction motors, 2 servo motors
    By Jonathan in forum Items For Sale
    Last Post: 30-09-2018, 04:18 PM
  3. WANTED: 2.2 KW 3 Phase Induction Motor
    By Chaz in forum Items Wanted
    Last Post: 23-11-2017, 06:18 PM
  4. Basics on control and positioning with stepper motors
    By richard2112 in forum Stepper & Servo Motors
    Last Post: 30-06-2014, 08:39 AM
  5. Replies: 2
