    The obvious question to ask is why, if there was a fuse, it was not accessible from the outside for replacement purposes? The answer, I think, is for the same reason that I don't stick fuses everywhere in my own control box. The fuse in this case did not protect the mosfets - it protected the rest of the upstream wiring and power supply from a potentially dangerous overcurrent situation causing a fire. Pound to a penny that the mosfets popped first, then the fuse blew to protect the rest of the system. The manufacturer knew this - no point in a replaceable fuse if the driver is dead anyway. Fuses are very important and shouldl not be forgotten - but just remember what they actually achieve and use them accordingly.
    On a more positive note it's interesting to see that these drivers use well-marked and easily available replacement mosfets, although I would be a bit hesitant about working on through-hole boards - haven't had to do that myself.
    MOSFETs due in tomorrow from Farnell... along with some other goodies. Neale - that's pretty much the purpose of a fuse - and anyone relying on one to protect semiconductors has a lot more optimism than me. The more I look at these drivers the more I like about the design - the accountants haven't got too close to these, just close enough to the training of the assembly workers :)
  1. Windows 10, is it better than the rest?
    By magicniner in forum Computer Software
    Last Post: 28-11-2019, 11:04 AM
  2. CNC Project - Guitar Neck (and the rest if I can get away with it)
    By Washout in forum Woodworking Project Showcase
    Last Post: 28-01-2018, 10:45 AM
  3. Higher end Chinese controllers?
    By m_c in forum Motor Drivers & Controllers
    Last Post: 22-10-2016, 10:04 PM
  4. Foot Rest Project and how I did nesting in Fusion 360
    Last Post: 24-09-2016, 11:57 AM
  5. NEW MEMBER: Back after a little rest
    By bogstandard in forum New Member Introductions
    Last Post: 27-02-2015, 07:12 PM
