    Lives in Plymouth, United Kingdom. Last Activity: 8 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I would read the data sheet and set the current to something reasonable. That is science.
    Once the machine is running, adjust it so that the motors run at a temperature that is just about as hot as you can comfortably hold, which is around 60C. That is engineering...
    Seriously, stepper motors are designed to run hotter than you might expect. More current gives better performance as long as you do not overheat them. Those current readings are really only a guide or a rough starting point, not absolute limits. Remember to set the stationary holding current to half (usually a dip switch setting) which helps keep them a little cooler while not moving.
  2. The Following User Says Thank You to Neale For This Useful Post:
  1. Windows 10, is it better than the rest?
    By magicniner in forum Computer Software
    Last Post: 28-11-2019, 11:04 AM
  2. CNC Project - Guitar Neck (and the rest if I can get away with it)
    By Washout in forum Woodworking Project Showcase
    Last Post: 28-01-2018, 10:45 AM
  3. Higher end Chinese controllers?
    By m_c in forum Motor Drivers & Controllers
    Last Post: 22-10-2016, 10:04 PM
  4. Foot Rest Project and how I did nesting in Fusion 360
    Last Post: 24-09-2016, 11:57 AM
  5. NEW MEMBER: Back after a little rest
    By bogstandard in forum New Member Introductions
    Last Post: 27-02-2015, 07:12 PM
