Thread: Add-on CNC build log
06-08-2009 #9
Minor progress last night - opened up one of my donated Dell ATX PSUs and armed with a multimeter started looking around for the ground-to-case connection as per the various instructions around e.g. here. Aiming to link three PSUs to give a 36V 10A supply.
Turned out to take about ten seconds - just follow the black wires back down to the PCB and there was an obvious jumper (J23) over to the case via a screw. Bit awkward getting in to cut it so ended up desoldering and pulling it out with needle nose pliers. Checking after with meter revealed it did the trick, so I did the second one as well.
Still a bit of wiring to sort and need to get some power resistors to provide a bit of load for them to go at but that's the main hurdle over I think as far as the PSU goes.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
