As mentioned I got the best results with single flute down cut, make sure they are nice and sharp. I used Belin but there are plenty of single flute down cut bits around... Choice is probably most limited by cutter length depending on what you want to do, although there is no problem doing 2 passes with the second pass below cutter height (as long as shank is same diameter as cutter obviously), it’s just slower. I think the Belin only go up to 38mm on a 6mm cutter.
I bought those here https://www.cncroutershop.com/uk_en/...wn-spiral.html
The most important thing I found is to use conventional milling and NOT climb.
Depth of cut is fairly unimportant. The foam is soft enough that it won’t test the rigidity of any half decent machine, same goes for width of cut and it more becomes a question of having swarf that can clear easily. I had good results using 16k rpm and 3,000mm/min on the 6mm tool, and I think around 20,000 on the 3mm.... but there’s certainly plenty of room to play around there.
For hold down I would box it in if working very close to the edge, and a vacuum plate would be the easiest way to keep it stuck down.Last edited by Zeeflyboy; 11-01-2019 at 02:30 PM.
11-01-2019 #2
06-04-2022 #3
Zeeflyboy / Tigger
Don't suppose either of you would be able to cut some of this foam to a spec?!
I've asked around quite a few companies, some had agreed, others can't get sorted by the required date (14th April)
If this is something either of you could potentially do, would be amazing, can pay for the service!
NEW MEMBER: Milling work required would appreciate some help and advice - New member
By reidy- in forum New Member IntroductionsReplies: 2Last Post: 04-05-2015, 10:21 AM -
Milling Machine Advice
By Washout in forum Milling Machines, Builds & ConversionsReplies: 28Last Post: 29-07-2014, 10:03 AM -
RFQ: CLOSED - Aluminium milling and anodising
By AlexTsekenis in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-05-2014, 10:11 PM -
Extra long end mills for milling foam
By gavztheouch in forum Marketplace DiscussionReplies: 6Last Post: 22-01-2014, 09:01 PM -
CNC milling large foam bucks - DIY or supplier?
By cloudy in forum Marketplace DiscussionReplies: 0Last Post: 05-03-2012, 12:08 PM
