Nice one! Is it a kind of elastic a bit? Or its like dense insulation foam? the fact that is Bicolor is amazing.
The latter i cut using finishing speeds for wood, hence 16k rpm and 1800mm/min. I have never played much adjusting speeds, as this worked from the beginning with nice finish. Then i am adjusting depth.
06-03-2017 #2
It's got good structure but somewhat soft and giving if you squeeze it... Nothing like a rigid insulation foam, and it bounces back rather than crushes. I believe that it's a type of polyethylene foam which is available in various densities - this one is 30kg/m3
It's actually two sheets - one 30mm yellow and one 5mm black. The plastazote stuff is available in black, white, red, blue yellow or they have some cheaper similar foam in black and white only. You can then heat weld them together (carefully!) using a hot air gun to create the bi-colour piece.
I've managed to find some clean looking machining of similar looking foam where they were using single flute down cutter, so i've ordered two of those (a 3mm and a 6mm) to have a try with.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
10-03-2017 #3
Right, nailed it I'd say!
The below is using a 6mm single flute down cut bit (belin). Conventional rather than climb, 16,000rpm, 3000mm/min feed rate and 15mm step down (except the test collet cut out was done with a ramping helix to get the wall angle smooth).
Came out nice and clean - now I'm happy to move on to actually making the proper inserts.
11-03-2017 #4
Well, milled really nicely but It was stuck down too firmly and i couldn't pull it off the bed without ruining the foam
At least I have some spare material.... sigh
26-03-2017 #5
Quick video of milling this stuff:
What I learned in case anyone is interested in having a go:
- When making multi layer stuff, it's much easier to use 3M super77 spray glue to stick the layers together... that is the glue that my research turned up and you can get it in this country for a fair enough price from farnell. While heat welding works, I found it quite tricky to get the right balance between hot enough to get a good weld and not too hot to deform or damage the foam.
- Down cut router bits are definitely the way forward, gives a much cleaner edge.
- Never climb! Conventional milling all the way.... climb gives a truly awful edge finish.
- If you ever get any foam stuck on the bit, hit feed hold immediately and clear it off... it can very quickly give you a fuzzy edge cut.
- Fast feeds are good, but single flute cutter is quite happy whizzing through at around 3,000mm/min or even less which is well within the reach of most machines.Last edited by Zeeflyboy; 26-03-2017 at 06:56 PM.
26-03-2017 #6
26-03-2017 #7
I do have one actually that i made a while ago - I just need to get the magnets to finish it off and actually use it!
NEW MEMBER: Milling work required would appreciate some help and advice - New member
By reidy- in forum New Member IntroductionsReplies: 2Last Post: 04-05-2015, 10:21 AM -
Milling Machine Advice
By Washout in forum Milling Machines, Builds & ConversionsReplies: 28Last Post: 29-07-2014, 10:03 AM -
RFQ: CLOSED - Aluminium milling and anodising
By AlexTsekenis in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-05-2014, 10:11 PM -
Extra long end mills for milling foam
By gavztheouch in forum Marketplace DiscussionReplies: 6Last Post: 22-01-2014, 09:01 PM -
CNC milling large foam bucks - DIY or supplier?
By cloudy in forum Marketplace DiscussionReplies: 0Last Post: 05-03-2012, 12:08 PM
