Wouldn't hold either of those up as great bench marks, all is not what it appears.!! . . With carefull buying along with attention to detail you will easily match both those in performance terms.
The build you show is something to be avoided with many design flaws.!!
If you can work with steel it will be much cheaper. Combination of steel frame and HD Aluminium profile for gantry makes for very strong machine. Combine this with profiled rails like Hi-win with correctly sized balls screws and the accuracy/performance will match any of those machines you mention.
The electronics are key part of good machine so no cutting corners in this department and it's here where it will make or break the machine. It's also the place that will set your machine apart from those costing 1000's more. It's here where we can help and guide you to buying the correct components.
I suggest you go look around the forum at some of the builds to get a feel for if you really have the skills and patience to build a machine. Be honest with your self here because there is more to this than first appears. Building a good machine requires patience and eye for detail. If done in rush or corners cut it will suffer so be sure you have the time needed.
Sometimes buying ready built works out easier and cheaper in long run because your cutting and making money sooner which pays for the machine. And you don't have the stress of building, testing, fault finding etc that does come with DIY.
If your not put off then start a build Log. Show the design you have in mind and ask any questions you may have, no matter how daft you think they are.
It's good idea to draw up a detailed design of the machine so there's no hidden surprises. Ideally a Cad model works best.
Good luck.
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
BUILD LOG: my router build - advice needed
By thomashomer1986 in forum DIY Router Build LogsReplies: 10Last Post: 02-12-2013, 11:45 PM -
Looking to buy a ~4'x4' CNC router, advice welcomed
By Franco in forum Marketplace DiscussionReplies: 1Last Post: 02-06-2013, 10:05 PM -
Help / Advice is this cnc router worth £666 plus £100 for postage
By dannyj2009 in forum Marketplace DiscussionReplies: 6Last Post: 10-04-2013, 01:29 PM -
Advice on which cnc router
By Xenophya in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 08-10-2012, 11:25 PM
