Thread: which breakout board?
Gerry is probably the best to answer this because he's got more experience/connections with uc300eth. However for me the things to look for are one that can use 24v for inputs and is powered by 24V not 5v or from USB. Unfortunately don't think £50 is going to buy one that will have these features.!
Personaly I will only use Cslabs controllers on machines I build so don't have this problem and rarely buy Bob's these days. If I was it would probably come from PMDX in the states as they are the only BOB I've used and not had issues with.
11-03-2017 #2
Let me jump on this request also... so Jazz I ordered 5 x AM882 drives at your suggestion, now I'm in the same boat as John but using the UC400ETH, need 4x regular channels ( one of them slaved ) another for 5th axis which I may or may not end up using, Spindle control, limit switches, and I wanted to drive some DC-AC relays easily using the breakout board, so if I receive error command from AM882's , or hard limit then my software will deactivate the realays. I will have the CNC water cooling pump, and Woodchip exctractor running on the "reset" relay. And a seperate e-stop signal going to the spindle inverter to stop it.
Is this the daddy I need " http://www.pmdx.com/PMDX-126
I noticed it accepts 26 volt also
11-03-2017 #3
Yes that's the Daddy I'd use if was needing a BOB.
Regards the Relays and faults/safety then you need it the other way around where they drive software not the other way around. Have the Drive fault output control a relay which then E-stops the system dropping the latching circuit so kills power to drives and also informs software/controller this happened. This is the only safe way to do it never rely on software for safety.
anyone using an e-cut 1 mhz usb breakout board
By nobby in forum Control Hardware & SystemsReplies: 10Last Post: 22-10-2018, 11:50 PM -
routout breakout board
By hazzard in forum Motor Drivers & ControllersReplies: 0Last Post: 20-09-2015, 09:21 PM -
Breakout board recommendations
By GND in forum General ElectronicsReplies: 15Last Post: 15-07-2015, 07:24 PM -
Breakout Board
By Tomnewry in forum General ElectronicsReplies: 2Last Post: 12-12-2013, 07:24 PM -
Breakout Board
By croy in forum Electronic Project BuildingReplies: 10Last Post: 18-08-2011, 07:50 AM
