Thread: Cutter accuracy
01-09-2017 #18
Neale, I have exactly the same problem, did you manage to resolve it?
I don't have stiffness problems on the machine, to test I am only cutting 3mm deep slots 1mm at a time, i have tried 0.5mm at a time.
I have set the steps in mach3 and can run the machine up and down the x and y axis all day at 3m/min and still go accurately back to the start point.
Not losing steps have dial gauges set on the x and y axis at the home, so i would see and changes.
I have measured the bits and they are spot on.
I am using aspire to generate the gcode
I have also setup Uccnc to see if its a Mach3 problem, still the same
2005mm ballscrews (not out of align)
I have tried cutting a few lines 25mm, 50mm, 75mm long using profile cut and 100mm, 50mm and 25mm square using pocket cut, all out by 0.2mm to 0.4mm
I tried 4 slots (for a guitar fretboard) that should have been
35.64 measured 35.98
33.64 33.86
31.75 32.00
Any ideas?
Bad accuracy with my cnc machine
By masinecc in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 23-04-2015, 06:59 PM -
1mm position accuracy for timing belt
By motomage in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 01-02-2015, 01:46 PM -
Tool diameter accuracy
By Neale in forum Tool & Tooling TechnologyReplies: 15Last Post: 05-03-2014, 11:18 PM -
Accuracy Problem
By richie00boy in forum Machine DiscussionReplies: 12Last Post: 09-09-2013, 11:24 AM -
Machine bed accuracy
By Colin Barron in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 03-11-2010, 11:24 AM
