Thread: Cutter accuracy
01-09-2017 #19
I have the same problem, the cut is always out between .2 and .4 mm
The steps have been set, there is no steps being dropped.
I set the steps with a 900mm rule, and checked the settings by moving the x axis about 10 times while holding it back with all my strength. still spot on.
I have checked the 6mm bit and I use aspire for the code.
I have made 25mm, 50mm and 100mm square pockets, 25mm 50mm 75mm slots, they are all out 0.2 to 0.4mm
I have tried Mach3 and Uccnc, both the same.
UC300-lpt5 motion controller and HG08 Breakout card
Stepper motors are direct drive, onto 2005 ballscrews (2 on x axis linked not slave), with dial gauges at the x and y homes (just to check)
Any ideas?
Bad accuracy with my cnc machine
By masinecc in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 23-04-2015, 06:59 PM -
1mm position accuracy for timing belt
By motomage in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 01-02-2015, 01:46 PM -
Tool diameter accuracy
By Neale in forum Tool & Tooling TechnologyReplies: 15Last Post: 05-03-2014, 11:18 PM -
Accuracy Problem
By richie00boy in forum Machine DiscussionReplies: 12Last Post: 09-09-2013, 11:24 AM -
Machine bed accuracy
By Colin Barron in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 03-11-2010, 11:24 AM
