    Maybe ;)
    Looking at getting one of the eBay offerings, all seem the same, probably a 60W model so i end up with about 30-40W at the cut.
    Watched loads of videos, realise the machines, as most chinese stuff does, needs a lot of fettling and tuning, realise that they over-drive the tubes to get more out - bad idea, and so-on so hopefully there will not be too many surprises in store.
    First question - most vids show them cutting white card/paper, supposedly because it looks good and shows defects well. I have a possible task in mind that uses BLACK card, about 0.25mm thick - will they cut this as easily? My guess is yes but...
    I was looking at building one but there is no way to put even the motion together for what these machines are going for so buying and fixing is the way forwards.
    Maybe ;)
    Yeah bought a blue and white one and it has not needed any work since buying it.
    Black card will not be an issue.
    https://emvioeng.com
  3. The Following User Says Thank You to komatias For This Useful Post:
    Looking at this one....
    http://www.ebay.co.uk/itm/2016627522...%3AMEBIDX%3AIT
    Should be ok, will expect to do some fine tuning but thats half the fun i think ;)
  5. #4
    Dave,
    It looks to be identical to mine.
    You are welcome to come and play with my 60 watt Chinese chappie before you part with your dosh. There's a bit about it here:
    http://madmodder.net/index.php/topic...html#msg126523
    and here:
    http://madmodder.net/index.php/topic...html#msg126442
  6. #5
    Thanks for the offer Andrew,
    I think i'm fairly certain it will need work and I'm ok with that, i like to go through and fine-tune stuff anyway, its a good way to learn all the dodgy parts and i had already spotted those terrible universal sockets - i've got some IEC ones in the CNC building parts box so they will go in pretty much exactly as your one.
    I put in an offer tonight, see if they take it or not :)
  7. The Following User Says Thank You to Davek0974 For This Useful Post:
  8. #6
    Ok, i ordered one this morning, fingers crossed.
    Few q's for starters...
    Are there any "preferred" sources of acrylic and laser-ply sheet ?
    Everyone just use the pump-in-a-bucket cooler, plain water, de-ionised water, any additives?
    Two things i will be getting is a 0-50mA meter for tube current and a power measuring probe/device - these seem pretty essential things for starters.
  9. #7
    Fred's Avatar
    Lives in Reigate, Albania. Last Activity: 24-04-2018 Has been a member for 9-10 years. Has a total post count of 34. Received thanks 4 times, giving thanks to others 1 times.
    Definitely don't blow through the coolant tubes to make sure they're not blocked! I did this and contracted a really nasty stomach bug. I can't remember what it was, but my wife's a GP and said they wouldn't normally test for it if you hadn't been somewhere like China on holiday.
    Definitely untangle that tubing. Also check the HV wiring isn't flapping around near the metal chassis like mine was. Basically treat the machine as a kit of parts that has been assembled by a 5 year old whilst watching cartoons.
  10. The Following User Says Thank You to Fred For This Useful Post:
  1. Please don't push 14A through that PCB !!!
    By Jonathan in forum General Electronics
    Last Post: 05-01-2017, 04:43 PM
  2. FREE: Green/Red/Black 3P push button rocker switches
    By Lee Roberts in forum Classified Ads, Buy, Sell & Swap
    Last Post: 08-05-2016, 07:38 AM
  3. Help with Mach 3 REF all Home Button
    By Kevin1970 in forum Artsoft Mach (3 & 4)
    Last Post: 23-04-2015, 10:54 AM
  4. push down plate,
    By jcb121 in forum Gantry/Router Machines & Building
    Last Post: 31-07-2013, 11:38 PM
  5. Donate Button
    By Ricardoco in forum General Discussion
    Last Post: 08-09-2011, 10:32 PM
