    LOL, rotary attachment is currently in Birmingham and finally got working tracking on the machine which is currently in Bremen, Germany.
    So much for "UK Shipment, Portsmouth" :)
    Oh well, one down, one to go....
    The rotary attachment arrived today - totally wrecked as the chuck had broken the shaft that mounts it and was loose in the box, unusable and a complete waste - the box that should have held the chuck was in there so why was it fitted??
    My thoughts were previous customer return item.
    emailed supplier with a photo.
    Oh dear, not good.
    My rotary attachment is still bubble wrapped but mine is the simpler, cheaper unit with no chuck, just a set of stepper driven 3 rollers to hold a glass or bottle by friction.
    Can't see it ever getting used.
    I did see another one of the type you have on a forum somewhere, where the spindle had pulled out of the upright because the bearing was a loose fit but it looked an easy fix if you could get redress off the seller.
    John S -
    This would be an easy fix - re-weld the plate and true up on the lathe but that's not the point :)
    See what they say in the morning.
    Broken weld, if you call it a weld...
    Put the chuck box in though, thats a nice touch...
    Nice wiring....
    JS probably saw my post here on Madmodder - see reply #23
    http://madmodder.net/index.php/topic...html#msg126523
    Oh, and my cable outer also was stripped too far back to use the clamps like yours, but I found that by friction warming the outer by gripping with a cloth and sliding it, I could ease the outer far enough down the wires to get under the clamps (which are too large a diameter to grip, but a bit of the serrated end of a tywrap makes up the gap sufficiently !
  7. The Following User Says Thank You to AndrewMawson For This Useful Post:
  8. #7
    Supplier reply - can i get it fixed locally and how much?
    I guess £50 will cover it :) See what they say.
  1. Please don't push 14A through that PCB !!!
    By Jonathan in forum General Electronics
    Last Post: 05-01-2017, 04:43 PM
  2. FREE: Green/Red/Black 3P push button rocker switches
    By Lee Roberts in forum Classified Ads, Buy, Sell & Swap
    Last Post: 08-05-2016, 07:38 AM
  3. Help with Mach 3 REF all Home Button
    By Kevin1970 in forum Artsoft Mach (3 & 4)
    Last Post: 23-04-2015, 10:54 AM
  4. push down plate,
    By jcb121 in forum Gantry/Router Machines & Building
    Last Post: 31-07-2013, 11:38 PM
  5. Donate Button
    By Ricardoco in forum General Discussion
    Last Post: 08-09-2011, 10:32 PM
