Thread: Crap chinese router problems
12-03-2017 #7
Don't start changing anything without knowing that it must be changed and that it solves the problems. It may however help if you'd install a trial version of Mach3 and run that as well. Are you using Modbus to set the set the spindle speed? Are you sure that VFD is a real Modbus capable VFD? Most cheap Chinese VFD are NOT real Modbus. The manual pages are just lousy scanned picture, not pdf, so you must read every word, can not search. It also seems incomplete because the communication is not described. So, if you run Modbus I would suggest to go back to basic digital control, in fact, start with manual control from the control panel. Take the next step when that works.
On going chinese 6040 problems
By amxen in forum Chinese MachinesReplies: 65Last Post: 03-06-2020, 08:46 AM -
More Problems with Chinese 6040
By Rye in forum Chinese MachinesReplies: 11Last Post: 07-12-2017, 01:13 AM -
Why are most cutters so crap?
By Tenson in forum General DiscussionReplies: 5Last Post: 17-10-2015, 01:51 PM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM
