Thread: Way out of my depth
13-03-2017 #4
Ok well that makes more sense. Don't worry about the Encoder for now as we'll just get motion first. Plus using the motor model I think it's 2050ppr which being quadrature means 8400ppr. So 8400 x 1500/60=210,000 PPS or 210Khz for 1500 RPM which motor is rated at. Mach3 default 25Khz would only get you aprox 180rpm.!!
I think the reason your not getting motion is because the drives are not recieving Enable signal. You'll need to use mach Enable output to turn on 5V relay which looking at Yaskawa manual you then pass 24V thru NO contact from terminal #47 (24V) on drive to terminal #40. This is the Servo On signal.
Or you can just put jumper wire between 47 & 40 but wouldn't advise that because means servo will be always active even when mach3 is in e-stop.!!! . . . Very dangerous with servo.!!Last edited by JAZZCNC; 13-03-2017 at 11:03 PM.
Pcb routing - Altering Cut Depth on the Fly
By iBeta in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 15-03-2016, 03:50 PM -
solidoworks tapped thread depth and blind hole depth
By reefy86 in forum CAD & CAM SoftwareReplies: 2Last Post: 10-11-2015, 04:14 PM -
Trigonometry help please, plunge depth for a v cutter!
By cncJim in forum Tool & Tooling TechnologyReplies: 13Last Post: 06-11-2013, 03:41 PM -
Z axis not cutting to required depth
By dinasblu in forum Machine DiscussionReplies: 10Last Post: 02-07-2012, 05:38 PM -
End mill depth 'stop' rings
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 10Last Post: 24-02-2010, 02:03 AM
