    I just realised i have never made an introduction thread for me or Lucy.
    I am Bam, I have used a CNC machine whilst at school, but that was about 20 years ago (god i feel old).
    I recently purchased a used (i think self build) machine.
    About Lucy, The machine:
    Dimensions: X: 1000mm Y: 1000mm
    Cutting area: X: 800mm Y: 720mm
    Interface: Parallel
    Software: Mach3, Vectric Aspire, Adobe Illustrator
    Driver board: CNC4X45A
    Limits: Home: X, Y, Z End: X,Y,Z e-Stop
    Base: 12mm MDF
    Gantries: 20x800mm Aluminum V-Slot
    Steppers: Y: 2 x Nema 23's ACT 23HS8630B (Nema23)*Step Angle:*1.8*Holding Torque:*1,5Nm*V/A:*2.7V / 3.0A
    X: 1 x Nema 23 57HS64-3008*Step Angle:*1.8 HOlding*Torque:1.5Nm *V/A:*1.6V / 4..2 A (http://cnc4you.co.uk/resources/57HS64-3008.pdf)
    Z: 1 x Nema 17 LDO Motors*LDO-42STH47-1684A (NEMA17)*Step Angle:*1.8*Holding Torque:*50 Ncm*V/A:*2.8V / 1.68A (http://reprap.org/wiki/NEMA_17_Stepper_motor)
    Drives: Y: Belt
    X: Belt
    Z: Ball and Screw
    Spindle: Kress 1050-FME
    I think originally was designed for modeling foam. So she isn't very heavy duty.
    The machine lives in Bradford, Although, for various reasons i am Usually in Manchester, London, Hertfordshire and Bradford.
ID:	21085 Click image for larger version.
ID:	21086 Click image for larger version.
ID:	21087 Click image for larger version.
ID:	21088 Click image for larger version.
ID:	21089 Click image for larger version.
ID:	21090 Click image for larger version.
Name:	cnc_20170228-002-Loose Kress.jpg
ID:	21091 Click image for larger version.
    P.s. how do i add a link to this thread in my footer?
  1. NEW MEMBER: Another CNC Novice
    By andyisko in forum New Member Introductions
    Last Post: 28-03-2019, 10:35 PM
  2. NEW MEMBER: Total Newbe to CNC
    By tommyb43 in forum New Member Introductions
    Last Post: 29-12-2016, 09:53 PM
  3. Total novice seeks advice on stepper motor drivers
    By R.Andersen in forum Motor Drivers & Controllers
    Last Post: 25-01-2012, 11:34 AM
  4. NEW MEMBER: Novice from Liverpool
    By John51 in forum New Member Introductions
    Last Post: 28-10-2010, 11:23 AM
  5. Total novice and lost
    By sfallan in forum Machine Discussion
    Last Post: 10-09-2010, 10:35 AM
