Thread: Advice please
I can just get in to measure it when I lower it, what am I measuring? I know the screw dia just need the pitch for the steps per
18-03-2017 #2
You could get a rough indication with a pair of dividers, if you set them to the narrow groves between the ball ways, ie on the OD of the screw. Then do as M-C instructed and use a dial gauge to get the actual distance traversed.
18-03-2017 #3
18-03-2017 #4
measuring gaps won't help if it's multi start which often are. Best way is try to mark the screw and rotate 1 rev and measure distance. Chances are it will 5mm or 10mm pitch so easy to see which.
However if your still using mach3 then it's simple really just let mach work it out for you using Set steps per in the settings tab.
18-03-2017 #5
