Thread: Advice please
17-03-2017 #8
1.25MOD is 32.69mm OD.
24DP is 1.09" (27.68mm), and 20DP is 1.308" (33.22mm), and 22DP does not appear to be a common size.
So assuming 1.25MOD and me reading the correct number from the chart, gives a pitch of 3.926mm per tooth, or 90.289mm for one rotation of the gear.
Or to assume 20DP, it would be 91.7194mm per rotation.
Are you sure it's a 23 tooth gear?
As even working backwards from 96.16mm, it doesn't fall on any common tooth size.
That's assuming I'm not making a complete hash of the calculations.
Off course, easier option would be just to measure the distance over as many teeth as possible and calculate the tooth pitch that way.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
