Page 1 of 4 123 ... LastLast
    Hi again, just me. this time im in need of help controlling the spindle from my board. However ive never seen this VFD and the spindle looks like the 2.2kw but on steroids with a ER25 collet.
    Can some good fellows help me control the spindle on/off via the board please?
    VFD is https://halk.ru/forum/resources/8/download?version=8
    and the model number is E380-4T0055G/0075P
    Board im using is the EDING CPU5A4E
    Quote Originally Posted by D-man View Post
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    The black wire appears to be linking the CM and FWD terminals, as well as providing a common feed (probably to provide the common for switching the inputs).
    You'll have to go through the settings menu (F3.0 - Pg32 in the manual) to see what X1, 2, & 3 have been configured to do.
    The TA/TC is an output, again you'd have to check the settings to see what it's set to (F3.8 - Pg 32 again).
    I'm not sure what Eding outputs, but you may want to reconfigure the drive so it uses an analogue 0-10V input to set the speed.
    Spindle is 3Kw.
    Spindle is 3Kw.
    Im sure it had 4.5 written on it. I may be wrong. But managed to get it all up and running now it's just the spindle I need sorting happy Sunday
    https://youtu.be/nHRegkThV8w
    OK Guys, everything is as per the manufacturers settings (in parameters pages) APART FROM the following:
    AUXILIARY RUNNING PARAMETER UNIT
    F4.8 - 0.50
    MULTI SPEED FREQUENCY
    F5.1 - 100
    F5.3 - 200
    F5.4 - 250
    F5.5 - 300
    F5.6 - 350
    F5.7 - 400
    OK Before i report with the Parameter settings i do know (thanks to google translate on the phone, AWESOME!), that the following wires were plugged into the old board for:
    RED: spindle Low
    GREEN: Spindle in
    YELLOW: Spindle High
    BLACK: was into 5v
    I will report back with these settings tomorrow.
    Sent from my iPhone using Tapatalk Pro
    Ok so when I put, X2 onto CM the VFD starts to spin up, however the spindle does not move and then I get an error code of FU.01 and it shuts down
    https://youtu.be/VRlPxEhJO_E
    At least we're getting somewhere.
    Does the spindle spin by hand?
  1. FOR SALE: Eding cnc controller
    Last Post: 01-08-2016, 03:31 PM
  2. Eding cnc
    By Ben-bee in forum CAD & CAM Software
    Last Post: 17-05-2016, 08:48 PM
  3. Setting ADTECH servos with Eding CNC software steps/AppUnit
    By D-man in forum Stepper & Servo Motors
    Last Post: 24-04-2016, 02:50 PM
  4. CONVERSION: Sieg X2 super with ball screws and Eding CNC controle
    By Soren DK in forum Conversion Build Logs
    Last Post: 11-04-2016, 08:40 PM
  5. Eding CPU5A4E controller and Siemens G110 VFD.
    By calgone in forum EdingCNC (CPU5, CPU5A)
    Last Post: 06-02-2015, 11:31 PM
