    OK Guys, everything is as per the manufacturers settings (in parameters pages) APART FROM the following:
    AUXILIARY RUNNING PARAMETER UNIT
    F4.8 - 0.50
    MULTI SPEED FREQUENCY
    F5.1 - 100
    F5.3 - 200
    F5.4 - 250
    F5.5 - 300
    F5.6 - 350
    F5.7 - 400
    First one that gets her fired up, will get a drink :)
    could really do with her up and running for tomorrow, so any help will be much appreciated, even if i can get it running in manual mode i just cant figure it out
    Lives in East Lothian, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    So it looks like it's just been wired to provide 3 different speeds, depending on what input is activated.
    What kind of output does Eding provide?
    For a quick get you going option, I'd think that provided you just connected one of the three speed input wires (red/green/yellow) to the common (black), then you'll get the spindle running.
    Eding CNC provides 0-10v and a tool option.
    http://www.edingcnc.com/upload/files...flyer_tech.pdf
    screenshot of the VFD section http://prntscr.com/eltm6t
    Pins screenshot http://prntscr.com/eltme8
    I'm going to assume that where the manual says Tool Output, it means there is an output that gets switched to turn the spindle on?
    If it is, then the quickest option would be to select one side of VFD speed inputs, connect it to the Tool Output, and connect the VFD CM to Eding Gnd/0V.
    Probably best to power up the VFD, and test this by connecting one of the speed wires, to the CM wire, and making sure the spindle starts. The VFD will most likely need to be powered up, before you make the connection, or it won't run. (it will depend on how the VFD is configured, as to whether it will run the motor immediately on power up)
    To get speed control, you'd need to wire the FWD terminal to the Tool Output, VC2 to the 0-10V output, and then join CM to GND/0V.
    I'm not sure if you'll have to change any settings in the VFD to get that working, but try it and see. If it doesn't work, make sure you are getting 0-10V at the terminals, and the Tool Output is switching. If you put a multimeter set to volts over the FWD/CM terminals, it should show a voltage with the spindle turned off (I'd guess it should be around 12V, but may vary depending on the VFD. It should certainly be higher than a couple volts), then when you switch the spindle on, it should drop to near zero volts.
    Cheers i will give that a pop and let you know
  1. FOR SALE: Eding cnc controller
    Last Post: 01-08-2016, 03:31 PM
  2. Eding cnc
    By Ben-bee in forum CAD & CAM Software
    Last Post: 17-05-2016, 08:48 PM
  3. Setting ADTECH servos with Eding CNC software steps/AppUnit
    By D-man in forum Stepper & Servo Motors
    Last Post: 24-04-2016, 02:50 PM
  4. CONVERSION: Sieg X2 super with ball screws and Eding CNC controle
    By Soren DK in forum Conversion Build Logs
    Last Post: 11-04-2016, 08:40 PM
  5. Eding CPU5A4E controller and Siemens G110 VFD.
    By calgone in forum EdingCNC (CPU5, CPU5A)
    Last Post: 06-02-2015, 11:31 PM
