Thread: Spindle help to EDING CNC
19-03-2017 #31
Look slike you have no speed set so it's running but at Zero speed.
19-03-2017 #32
19-03-2017 #33
19-03-2017 #34
Ok it's doing something. It's controlling via the software but not firing up
https://youtu.be/98LXdpYtOTw
Sent from my iPhone using Tapatalk Pro
19-03-2017 #35
19-03-2017 #36
19-03-2017 #37
Should I turn the other wires off in the VFD, maybe it's looking for those?(Green/red/yellow )
19-03-2017 #38
if this doesn't work then you probably not got voltage coming out of the eding so test voltage. @ s12000 you should have around 5v
19-03-2017 #39
ring me if still got number
16-01-2019 #40
Ok Guys had a bit time to revisit this. Your help would be very much appreciated.
The above options don’t work, however after a bit of fiddling, UV managed to get the spindle to switch on and off with the software.
My question is, what will control the speed? I’ve got 0-10v coming from the PWM and increases when spindle speed on the pendant wheel.
I’ve tried connecting to AC1&2 and also VC1&2 with no luck. I’m guessing it’s a setting in the VFD but I can’t see it.
It’s also worth mentioning that if I put PWM to X1-2-3 or 4 I get a separate set speed on each.
Please help guys, half way there!
https://youtu.be/b2cbv0fuKj4
FOR SALE: Eding cnc controller
By Web Goblin in forum Items For SaleReplies: 4Last Post: 01-08-2016, 03:31 PM -
Eding cnc
By Ben-bee in forum CAD & CAM SoftwareReplies: 0Last Post: 17-05-2016, 08:48 PM -
Setting ADTECH servos with Eding CNC software steps/AppUnit
By D-man in forum Stepper & Servo MotorsReplies: 55Last Post: 24-04-2016, 02:50 PM -
CONVERSION: Sieg X2 super with ball screws and Eding CNC controle
By Soren DK in forum Conversion Build LogsReplies: 2Last Post: 11-04-2016, 08:40 PM -
Eding CPU5A4E controller and Siemens G110 VFD.
By calgone in forum EdingCNC (CPU5, CPU5A)Replies: 4Last Post: 06-02-2015, 11:31 PM
