Thread: SYIL Power Drawbar
Hi Pete, after the sad demise of my coventry easy change adaptor, im now looking at other quick change tool syatems for the Syil. I dont suppose you still have the cad files?
07-05-2019 #2
The Following User Says Thank You to petemilligan For This Useful Post:
07-05-2019 #3
I am
08-05-2019 #5
- Standard old butterfly. You have space & might want to beef up the air piston from the small one I have.
- Find a 12 point socket for the drawbar.
- Air plumbing (in my case) used 3 air solenoids.
- The long strip in the design suits a limit switch to start the wrench.
- Cut an internal relief for the piston clamp
- Source a couple of linear bearings for the wrench plate travel
- The bars were silver steel (what I had in stock at the time), they're holding up fine.
https://a360.co/2J9wMhg
Hope this helps.Last edited by petemilligan; 08-05-2019 at 07:13 AM.
08-05-2019 #6
syil x4
By geoff in forum Machine DiscussionReplies: 8Last Post: 30-11-2016, 07:35 PM -
KX1 Drawbar too long?
By mbcx4jrh in forum Sieg Milling MachinesReplies: 8Last Post: 17-09-2016, 05:42 PM -
DIY Spindle Drawbar?
By Chaz in forum Spindles & Drive MotorsReplies: 4Last Post: 15-09-2016, 03:55 PM -
Budget Power Drawbar
By needleworks in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 17-12-2015, 11:36 AM -
Warco Drawbar woes...
By irving2008 in forum Machine DiscussionReplies: 7Last Post: 22-12-2008, 12:56 AM
