    & Video
    Hi Pete, after the sad demise of my coventry easy change adaptor, im now looking at other quick change tool syatems for the Syil. I dont suppose you still have the cad files?
    Quote Originally Posted by Benja View Post
    I do. Using Fusion?
    Pete
  4. The Following User Says Thank You to petemilligan For This Useful Post:
  5. #4
    I am
    Quote Originally Posted by petemilligan View Post
    I do. Using Fusion?
    Pete
    Fantastic! :D I am as it goes
    Is it any old butterfly wrentch or a specific brand/type?
  7. #6
    • Standard old butterfly. You have space & might want to beef up the air piston from the small one I have.
    • Find a 12 point socket for the drawbar.
    • Air plumbing (in my case) used 3 air solenoids.
    • The long strip in the design suits a limit switch to start the wrench.
    • Cut an internal relief for the piston clamp
    • Source a couple of linear bearings for the wrench plate travel
    • The bars were silver steel (what I had in stock at the time), they're holding up fine.
    https://a360.co/2J9wMhg
    Hope this helps.
  8. #7
    Hope this helps.
    Thats very good of you. thank you :) couldnt understand what you meant then for a sec - so a roller type limit switch will start the wrentch as the piston ends it stroke ? I pretty sure ive got it.
  1. syil x4
    By geoff in forum Machine Discussion
    Last Post: 30-11-2016, 07:35 PM
  2. KX1 Drawbar too long?
    By mbcx4jrh in forum Sieg Milling Machines
    Last Post: 17-09-2016, 05:42 PM
  3. DIY Spindle Drawbar?
    By Chaz in forum Spindles & Drive Motors
    Last Post: 15-09-2016, 03:55 PM
  4. Budget Power Drawbar
    By needleworks in forum Milling Machines, Builds & Conversions
    Last Post: 17-12-2015, 11:36 AM
  5. Warco Drawbar woes...
    Last Post: 22-12-2008, 12:56 AM
