Page 2 of 2 FirstFirst 12
    Thanks Robin,
    However, am i right in thinking that's only possible when using unsupported round rails on z?
    I think I'm probably interpreting your drawing wrong, as there's a lot of stuff there and I'm not sure how it all fits together in 3d, do you have a side on view?
    What you could do is slip pairs of linear blocks on to two pairs of linear rails, lay two rails on top of 2 rails at right angles then slide the blocks around a bit and see where the metal of the Y and Z slides can fit in around it.
    Does that make sense?
    ok, will give it a go, thanks.
    Aha!
    I think i see now. Playing with two pairs of rails it took about 60 secs.
    I will take some photos & do a couple of drawings later this evening. (i'm supposed to be working now... shhh)
    Well i think Robin's idea is pretty nifty, but i don't think it's going to work for me, as the rails i have are not long enough!
    A good example of not buying until the design is finished!
    The only way i can get to sensibly work is as per the drawings below.
    The Z table must fit between the Y blocks which means the y blocks are spread quite wide.
    In this case restricting my Y movement to about 250mm which is too small (I'm aiming for 350mm)
    I do quite like it though, it makes for a wider Z assembly than usual, but makes it very compact in other respects . (always some tradeoffs!)
ID:	21189   Click image for larger version.
Name:	YZ test A (Large).png
ID:	21190   Click image for larger version.
Name:	YZ test C (Large).png
ID:	21191   Click image for larger version.
Name:	YZ test D (Large).png
ID:	21192   Click image for larger version.
Name:	YZ testB (Large).png
ID:	21193   Click image for larger version.
Name:	YZ test E (Large).png
ID:	21194   Click image for larger version.
Name:	YZ test F (Large).png
ID:	21195   Click image for larger version.
Name:	YZ test G (Large).png
  6. #16
    oops, forgot the ballscrew!
Name:	YZ test v5 v6 B.png
ID:	21198   Click image for larger version.
Name:	YZ test v5 v6 A.jpg
ID:	21197   Click image for larger version.
Name:	YZ test v5 v6 C.png
  1. Fixed z axis to gantry design
    By Lachlan in forum Gantry/Router Machines & Building
    Last Post: 20-10-2015, 09:50 PM
  2. "Hacking" and "Modding"
  3. Replies: 0
    Last Post: 12-11-2014, 09:14 AM
  4. Setting up "System 45" 3 axis unit by DIYCNC
    By StevenT in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 03:22 PM
  5. "Racks" VS "ball screw"
