  1. #8
    A half way to Robin's suggestion to reduce the overhang would be to place the Z screw outside the blocks so the risers (in red on "A") can be removed.
    This would reduce the overhang by 30mm, but widen the Y plate by 75mm to accommodate the screw. Although some weight could be saved by having a cut out as in drawing C1
    However the risers also serve to stiffen both Y & Z plates, so i'm not sure.
    I would be interested to know anyones thoughts on this (or any other part)
    Note: The orange X & Y plates are 10mm steel guage plate it would be easy to up them to 12 if i removed the risers, only adding 4mm to overhang
    Drawing B & C are the same just different angles.
Name:	YZ test v2 A.png
ID:	21169   Click image for larger version.
Name:	YZ test v3 B.jpg
ID:	21170   Click image for larger version.
Name:	YZ test v2 C.jpg
ID:	21171   Click image for larger version.
Name:	YZ test v2 C1.jpg
  1. Fixed z axis to gantry design
    By Lachlan in forum Gantry/Router Machines & Building
    Last Post: 20-10-2015, 09:50 PM
  2. "Hacking" and "Modding"
  3. Replies: 0
    Last Post: 12-11-2014, 09:14 AM
  4. Setting up "System 45" 3 axis unit by DIYCNC
    By StevenT in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 03:22 PM
  5. "Racks" VS "ball screw"
