Page 3 of 3 FirstFirst 123
  1. #21
    Quote Originally Posted by Lloyd Barnes View Post
    That was my logic too but the inserts still seem to be available in left or right handed versions which makes no sense to me.
    You mean for the tools that can be used both for turning & milling like the one I linked to?
    It's because you do need left and right hand inserts for some turning operations, I always thread away from a shoulder and from the bottom of a hole outwards and it's handy to have both LH & RH threading inserts.
  2. #22
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    The LH/RH in that respect is to do with the physical position of the cutting edge, not the type of thread.
    There are holders/inserts available for turning that require angled shims, to ensure the insert is cutting at the correct angle for the required diameter, and ensure the correct thread form is produced. Larger diameters for a given pitch, have a less angled thread, so to ensure a 100% correct thread form, the cutter has to be angled to compensate for the thread angle, however if you need that level of accuracy in your threads, you probably won't even be considering thread milling.
  3. #23
    If you need a full thread right to the bottom of a flat bottomed blind hole you probably won't even be considering anything other than thread milling.
    If you need a thread with specific start/finish points for alignment of two mating parts you probably won't even be considering anything other than thread milling.
    If you want one tool in your drawer that will get you a working part covering a huge range of threads you probably won't even be considering anything other than thread milling.
    Job specific threadmills can produce perfectly accurate thread forms and full forms too, not partial, what you have to understand is that the form of the tooth on the tool differs not just for different thread angles but also for different diameters of tool, outside threads versus inside threads and different ranges of Major Diameter, knowing these the manufacturer designs a cutter profile which when swept through the work and following a helical path generates the correct thread form.
    Single point inserted thread milling tools are a great thing to have around, they are specifically produced because they allow a wider range of threads to be cut, albeit with reduced accuracy, but in this situation it is clearly incumbent on the programmer/operator to ensure the resulting thread is close enough to spec to be acceptable.
    If you need a higher level of accuracy in your threads you probably won't even be considering not buying the correct threadmill for the job. ;-)
    - Nick
  4. #24
    Is that to go with the 90 degree hole the designer wants drilled at the bottom of the blind hole?
    Rigid tapping? Plus any good lathe will able to control the exact thread start point.
    To give you a comparison to think about, why do gear hobs have to be offset at an angle from what they're cutting so accurately?
    You could cut a gear keeping everything perfectly inline, and you'd still get a gear with the correct number of teeth, but would the tooth form be correct?
    For over 99.9% of uses, a thread mill will produce a perfectly acceptable thread. I was just highlighting where it might not be acceptable, but the fact is, very few people would be able to test the difference. For those of us posting on here, we're far more likely to have problems with a milled thread not being perfectly round, let alone having problems with the correct thread form.
  5. #25
    If your mill doesn't cut circles that are round one assumes you'd realise thread milling isn't for you but if you haven't done any thread milling and so haven't read around the subject to a reasonable extent then this-
    http://www.productionmachining.com/a...g-makes-sense-
    Might help with understanding Thread Milling and it's capabilities :D
    Note. Better Finish, Lower Power Requirement and Fuller Thread Profile than tapping ;-)
    - Nick
  6. #26
    It's an Apples to Oranges comparison because angling the hob relative to the work lets you use one hob for a variety of gear sizes and pitch angles, even racks, it's not relevant to thread milling because Thread Mills are made Inside/Outside specific and for a set pitch and range of Major Diameters, these are all but 3 of mine (the other 3 live in holders by the mill), each is for a specific job -
    - Nick
  1. Single Point Thread Mills
    By matt-b2 in forum General Discussion
    Last Post: 18-01-2016, 08:06 PM
  2. CONVERSION: Re-Built a used CNC mill machine to the point of 80%
    By dudz in forum Conversion Build Logs
    Last Post: 20-03-2014, 06:44 PM
  3. Setting the zero point on a CNC lathe
    By Robin2 in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 20-10-2013, 10:37 PM
  4. Setting the zero point on a CNC lathe
    By Robin2 in forum Machine Discussion
  5. Setting a start point.
    By jrob3rts in forum Computer Software
    Last Post: 17-06-2012, 12:36 PM
