Thread: Single point thread tools
That way you will also need the budget to buy a cutter for each pitch you wish to cut.
I have cutters capable of full thread depth in a single pass for frequent jobs but a single point cutter can give you a lot of flexibility for one-off jobs and you don't end up with a drawer full of "once-used" threadmills.You think that's too expensive? You're not a Model Engineer are you? :D
23-03-2017 #2
Something to put on the shopping list - slightly further down than the CNC vertical mill conversion...
23-03-2017 #3
The reasoning is I have 4 nuts to make. 75mm diameter thread, can you imagine the cost of a 75mm diameter tap!! I would use it twice and in fact need 2 (2 nuts LH thread, 2 RH).
Single point threading seems a very sensible option as I'll be able to use it again for other large but different threads. I'd only need to buy a LH and a RH insert. That's assumes I can find one of course!Last edited by Lloyd Barnes; 23-03-2017 at 07:00 PM.
23-03-2017 #4
Do you need two different inserts? Surely the only difference between cutting LH and RH threads is the movement in the Z axis?
23-03-2017 #5
23-03-2017 #6
That was my logic too but the inserts still seem to be available in left or right handed versions which makes no sense to me.
I need to spend some time browsing the links provided earlier in this thread at the weekend.
24-03-2017 #7
You mean for the tools that can be used both for turning & milling like the one I linked to?
It's because you do need left and right hand inserts for some turning operations, I always thread away from a shoulder and from the bottom of a hole outwards and it's handy to have both LH & RH threading inserts.You think that's too expensive? You're not a Model Engineer are you? :D
Single Point Thread Mills
By matt-b2 in forum General DiscussionReplies: 9Last Post: 18-01-2016, 08:06 PM -
CONVERSION: Re-Built a used CNC mill machine to the point of 80%
By dudz in forum Conversion Build LogsReplies: 13Last Post: 20-03-2014, 06:44 PM -
Setting the zero point on a CNC lathe
By Robin2 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 20-10-2013, 10:37 PM -
By Robin2 in forum Machine DiscussionReplies: 7Last Post: 20-10-2013, 10:37 PM -
Setting a start point.
By jrob3rts in forum Computer SoftwareReplies: 14Last Post: 17-06-2012, 12:36 PM
