    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Does the voltage change when you work the switch?
    I don't have a manual for the bob just for the machine itself. ive enclosed some photo's of the bob and the main board
ID:	21226   Click image for larger version.
ID:	21227   Click image for larger version.
    Hi Kev
    the photo of the breakout board is not close enough to read the lables for the connectors
    is this correct ?
Name:	breakout board inputs.JPG
    also does this 24V DC LED indicator light ???
Name:	breakout board 24V power LED.jpg
    John
    Hi John sorry for the delay in replying iv'e just got in from work. The top photo of the bob you've labeled is correct, and the led is lit when powered up
    Hi Kev
    going by the LED indicators the board has the DC supply OK
    and the onboard 5V regulator is working
    so I would of expected the board to work
    with out a board to test my self I'll have to do another web search to see if I can find any more information
    John
    Hi...as per my knowledge when the limit switch is closed, the EL817 opto isolator's NPN transistor will ground the printer ports input pin. The breakout board does not have any pull up resistors to ensure a printer port input is at a valid logic high when the limit switch is open.
    assembly circuit
  1. Limit switch problem
    By ECCO in forum General Electronics
    Last Post: 25-12-2015, 11:28 AM
  2. Another Home - Limit switch question
    By Cube3 in forum General Electronics
    Last Post: 26-12-2013, 07:51 PM
  3. Limit and Home Switch Choice
    By Wobblycogs in forum General Electronics
    Last Post: 02-12-2013, 06:16 PM
  4. FOR SALE: Z axis with Home/limit switch and Nema 23 3nm
    By Shinobiwan in forum Items For Sale
    Last Post: 02-02-2013, 10:54 AM
  5. bounce off home switch.
    By motoxy in forum Machine Control Software
    Last Post: 30-08-2012, 12:26 PM
