Thread: Home Switch Problem
Hi Kev
OK
PM sent
27-03-2017 #2
John, I suspect you've got the optos in the wrong order.
If you look at the traces on the top side, I'd say the top opto is P10, and it's track runs down the outside of the limit switch connector to the E-Stop connector. The tracks of the other 4 optos seem to match up nicely with the Limit Switch connector, and I wouldn't expect the bottom opto track to run the way it does if it was going to the E-stop connector.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
06-04-2017 #3
Hi m_c
from post 45 "John, I suspect you've got the optos in the wrong order"
you are correct
now I have looked more closely
during the last few days I have installed mach3 on 3 PC's
IBM thinkcentre , Dell optiplex 755 and a PC built using a ASUS H110M-R motherboard
so I should be in a better position to test Kevins mach 3 settings
John
PS
as I can't upload a PDF data sheet on DC to DC converters
a link can be found here-
http://uk.rs-online.com/web/p/isolat...rters/1914922/Last edited by john swift; 06-04-2017 at 12:56 PM. Reason: add PS link to RS Components for DC DC converters
Limit switch problem
By ECCO in forum General ElectronicsReplies: 7Last Post: 25-12-2015, 11:28 AM -
Another Home - Limit switch question
By Cube3 in forum General ElectronicsReplies: 6Last Post: 26-12-2013, 07:51 PM -
Limit and Home Switch Choice
By Wobblycogs in forum General ElectronicsReplies: 25Last Post: 02-12-2013, 06:16 PM -
FOR SALE: Z axis with Home/limit switch and Nema 23 3nm
By Shinobiwan in forum Items For SaleReplies: 6Last Post: 02-02-2013, 10:54 AM -
bounce off home switch.
By motoxy in forum Machine Control SoftwareReplies: 18Last Post: 30-08-2012, 12:26 PM
