    Lives in East Lothian, United Kingdom. Last Activity: 9 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 375 times, giving thanks to others 9 times.
    John, I suspect you've got the optos in the wrong order.
    If you look at the traces on the top side, I'd say the top opto is P10, and it's track runs down the outside of the limit switch connector to the E-Stop connector. The tracks of the other 4 optos seem to match up nicely with the Limit Switch connector, and I wouldn't expect the bottom opto track to run the way it does if it was going to the E-stop connector.
    Hi m_c
    from post 45 "John, I suspect you've got the optos in the wrong order"
    you are correct
    now I have looked more closely
Name:	Limit Switch tester & partial TX14175 circuit.jpg
    during the last few days I have installed mach3 on 3 PC's
    IBM thinkcentre , Dell optiplex 755 and a PC built using a ASUS H110M-R motherboard
    so I should be in a better position to test Kevins mach 3 settings
    John
    PS
    as I can't upload a PDF data sheet on DC to DC converters
    a link can be found here-
    http://uk.rs-online.com/web/p/isolat...rters/1914922/
    Last edited by john swift; 06-04-2017 at 12:56 PM. Reason: add PS link to RS Components for DC DC converters
  1. Limit switch problem
    By ECCO in forum General Electronics
    Last Post: 25-12-2015, 11:28 AM
  2. Another Home - Limit switch question
    By Cube3 in forum General Electronics
    Last Post: 26-12-2013, 07:51 PM
  3. Limit and Home Switch Choice
    By Wobblycogs in forum General Electronics
    Last Post: 02-12-2013, 06:16 PM
  4. FOR SALE: Z axis with Home/limit switch and Nema 23 3nm
    By Shinobiwan in forum Items For Sale
    Last Post: 02-02-2013, 10:54 AM
  5. bounce off home switch.
    By motoxy in forum Machine Control Software
    Last Post: 30-08-2012, 12:26 PM
