    Right well I have finally moved back to the uk, I thought it was best to wait until I was back so I could have a bit of time to re asses, think and deside what I had room for and also take a look at the steel that I was given. It is 100x100 x5mm wall so a little heavier than what people have said so hope that is ok and I have nearly 20m in total so should be plenty there although was thinking of making the legs of something a little lighter weigh?
    I have decided on a work area that will allow a max 1220 x 600 to be cut but with the focus on aluminium and forget full sheets for the moment.
    I don't really want to do the hole epoxy level thing so will need to figure the best place to build the adjustment in to the axis's
    If it is easier and up for the job I will use aluminium extrushion for the gantry.
    So back to the drawing board and to start planing how to do the frame.
ID:	21555   Click image for larger version.
    Quote Originally Posted by charlieuk View Post
    My machine uses 100x50x3 steel box for the long X rails supports, giving around 1550mm travel so not that different to your plan. I also added steel strip inside to give me something to drill and tap for rail hold-down bolts, which is why I could manage with 3mm. However, my rails dip around 1.5mm in the centre. I don't know if the steel was bent to start with, or if it's welding distortion, or something else. The moral is, though, that unless you can really measure and control the materials and the build methods, you have to allow some way to correct the inevitable errors that creep in. I ended up using a mixture of epoxy and shimming, but I'm not saying that that's the best method, just one that worked in this case. Good luck with the build, and don't take anything (like steel box section being straight!) for granted...
    once I have selected the best lengths to use my plan was depending how much they are out to get two of the faces machined flat or if to far out weld a strip to the top and get that machined instead.
    I'm thinking doing the same raised rail design but then have flat plates on the verticals to bolt the long rails to so I can shim them or what ever is needed.
    Quick question.. If I build a square frame for the bed is it better to cut the corners at 45deg and then weld them like that or just butt joint them. I'm thinking if I do it at 45 there less likely to distort and I will get a tighter joint. I will be tig welding rather than mig.
  1. BUILD LOG: DIY Plasma build - Attempt number 1
    By Gigalith in forum DIY Plasma Build Logs
    Last Post: 13-12-2016, 06:42 PM
  2. WANTED: part number
    By tinshak in forum Items Wanted
    Last Post: 10-02-2015, 10:10 PM
  3. Help With a number of build issues & uncertaintities
    By bigstu67 in forum Gantry/Router Machines & Building
    Last Post: 24-09-2014, 03:54 PM
  4. BUILD LOG: A3 Router Build
  5. Number plate dies and a Sieg KX3 CNC Hobby Mill
    By p4tvw in forum Milling Machines, Builds & Conversions
    Last Post: 14-04-2010, 04:51 PM
