Hello
ive got these as a full setup on my router. bought from Zappautomation and i have never had a problem with them except 2 driver bards burning out but that was my fault with the wiring.
Once i put right board to right power supply all has been faultless and that will be around 5 yrs ago.
i recommend them no problem. Expensive and closed loop but you get what you pay for.
Hope this helps.
15-03-2018 #3
Hello
ive had a look and the only make i can see on the driver case is Leadshine.....not sure if this is any good to you.
I do know that my setup has been supersceeded but with what i dont know.
Skiprat
The Following User Says Thank You to Skiprat For This Useful Post:
15-03-2018 #4
Thanks.
All these drivers are different.
So far, I have found this information, maybe useful for someone:
Leadshine: HBS86, HBS86H - They should be similar to models ES-D808 and ES-D1008. Tuning software is available, parameters can be adjusted.
JSS Motor: HSS86 - No tuning software. Parameters cannot be changed.
JMC Motor: 2HSS86H - Parameter upload is possible via a handheld device sold separately. There are rumors, that a PC tuning software is available, too.
16-03-2018 #5
The Leadshine HBS series was the original easily available closed loop stepper system.
The JSS and JMC versions are copies.
Leadshine has since updated their system, but nobody else has.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
16-03-2018 #6
Thanks for sharing this info. Does it mean that all of them perform roughly the same? What is your opinion? Is the updated Leadshine worth the money for a hobby CNC builder? They cost almost twice as much.
16-03-2018 #7
I have used both genuine Leadshine and the Copies. There is very little difference between them in performance terms. However, the Leadshines are more configurable regards settings if you need to play around with resonance tuning etc. But Digital drives are that good these days you very rarely need to anything with them.
I've used both these on several machines and I'm very happy with them.
https://www.aliexpress.com/store/pro...5d631f1cWtkEZV
https://www.aliexpress.com/store/pro...3025453aY8dvSN
CS-LAB AC-servos + SIMdrive
By blim in forum Stepper & Servo MotorsReplies: 0Last Post: 20-02-2017, 12:52 PM -
Mitsubushi Servos
By Chaz in forum General ElectronicsReplies: 0Last Post: 24-04-2016, 08:08 PM -
switching from steppers to servos - STEP / DIR control
By dsc in forum Stepper & Servo MotorsReplies: 6Last Post: 18-06-2014, 12:41 PM -
FOR SALE: Various Steppers, servos, drives for sale
By Peter. in forum Items For SaleReplies: 2Last Post: 02-02-2014, 09:56 PM -
Open Source Servos
By D.C. in forum Open Source Designs & PlansReplies: 0Last Post: 07-03-2013, 07:29 PM
