They aren't servos at all, they are closed loop steppers...
Jazz - all very well saying don't be fooled by that link, but I have yet to see any quantitive testing that shows there is no or very little difference between closed loop and open loop steppers... all the comparisons I have seen have shown them to be superior. Have you come across any evidence to support the assertion that there are open loop systems that can get close to the efficiency of a closed loop system? The 3 phase ones also have a higher resolution at 1.2 degrees per step rather than the 1.8 of most 2 phase steppers, which is about a 30% improvement.
As for being able to use higher voltage, the model he linked to is also rated to 2,000rpm - higher voltage is unlikely to help you get beyond that speed on traditional drives I would say? The closed loop steppers manage to maintain higher torque at high speeds too when compared to open loop which is useful to consider when talking about performance at higher speeds.
As to the playing catch up - it really depends on what you are making and where the problem occurs. Lets say your g-code has a slight blip and you lead out from a contouring cut into a full depth cut of the surrounding stock (it's happened to me!) - were open loop steppers to lose some steps from that they would then go on to ruin your work piece where the closed loop would have caught back up before it even moved to the next operation... also depending on the work and the point that it happens, a small defect may be acceptable (or may not even show on the final piece if it happened while clearing or doing any work away from a final contour or surface) and the rest of the operation would still be dimensionally correct. Lost steps would go on to offset the entire work from then on and completely ruin the whole piece.
As I said, if you just view them as normal steppers I think they are a good choice, and arguably one of the better choices if staying with steppers. They aren't really that much more expensive than good digital drives and decent quality stepper motors but do honestly have some advantages too so if the extra expense isn't an issue then I don't see why you shouldn't consider them among your options. Personally I just consider them as a high end stepper system, and they've fulfilled all my expectations so all I can say is I've been very happy with them
28-03-2017 #2
Zeeflyboy- The reason you probably haven't seen any evidence in tests is because they are trying to sell or promote Closed loop. Also they are not comparing Apples with Apples in most cases.
Like you rightly point out Closed loop motors are 1.2degree and 3 phase. I'd bet strong wagger they are using 2phase 1.8 degree motors on the Open loop test.
I'd also put another wagger that they are not using Digital drives on the Open loop but old Analog drives.
True test would use Digital drives with 3phase motors (which can be bought.) In this case the only difference is the Encoder and Closed loop side of the DSP which doesn't make any difference to performance of the motor. Closed loop drive is just Digital drive with Closed loop option inside the DSP. This can be proven by turning the closed loop side off which can be done via software in some drives. The performance of the motor doesn't change with it turned off.
Do this then the only difference between Digital drives like leadshine EM/AM and the Closed loop system is the motor which is connected. My argument was never that standard steppers equal 3 phase steppers and I said all along 3ph motors are smoother which is mostly because of the 1.2deg resolution.
Now my comments regards standard 1.8 Degree steppers and Digital drives comes from years of experience building machines which use them. My comments regards Closed loop come from using and testing them on several machines over the last 18mths. I can tell you and everyone else that the difference in performance is minimal, yes slightly smoother but thats about it.
Now where the AM/EM drives do trump the Closed loop is that they have 80Vdc limit not 50Vdc. This translates to more speed and more torque which for router is crucial, not so much for mill.
Your argument regards Catching up is weak at best because simple truth is that if falls behind there will be some error. Chances of this happening only on that one axis while others are not moving and on part of the work piece which is not important have Odd's higher than winning the lottery.
What happens if this happens 10hrs into 12hr job of 3D mould with 3 axis moving together cutting expensive piece of aluminium.?? . . . . What good is Closed loop here if falls behind.?
Also if the Open loop is losing steps then it's in-correctly tuned or pushed too hard. In which case this would happen to closed loop just the same if pushed past it's capabilty's. Only difference is it would or should Fault before stalling. Good Digital drives like EM/AM will however quickly Fault when it see's Stall so again very little difference because both have messed up.!!
Now to the Price argument.! . . . I agree Closed loop are now lot cheaper but still they have way to go. AM882 can be bought for £60-70 3-4nm Motor for £35. The Leadshine Closed loop shown was £179 and is only 2Nm.!! . . . . Nearly £80 difference PER AXIS. for very little gain other than bragging rights.!!
29-03-2017 #3
I never understood the significance of closed looped steppers at that price point. Plus i pointed already a couple of times in forums where cheapest servos could be bought.
400w AC servo motor could be bought for ~180$ together with drive. JMC motion. 60ASM400 +MCAC808 , not sure of actual prices so have to check. Also they sold the closed loop stepper 3nm motor and 2HSS86H driver for around 130$ . that prices were when you buy 4x. Obviously a PSU must be fashioned. That includes cables so price was great.
So forget about the Leadshine for the moment, there are other players. That was an year ago. Now may be even sth else new on horizon.
29-03-2017 #4
Seems to generally be about $220-250 (before postage) to source from china for those? Comes in at around $100 more than the leadshine closed loops per axis from the same sources (which vary from around $120-170 before postage), certainly not bad if they work well.
They are definitely on the cheaper end of what I've seen for servos (400W I've always seen more for $450 ish), are they what you are using? Could be tempting to try out at that price in the name of... science...
Jazz - we'll have to agree to disagree on the usefulness of the closed loop in terms of error, I'm still of the opinion that for certain applications it is nice to have even if not essential. I believe it worked out at around £130ish per axis for me all costs included (although granted the dollar was significantly weaker back then pre-brexit) so a premium of about 40 quid per axis over the setup you are speaking of.
I just want to be clear though, I have absolutely no doubt that the setup you are speaking of is fantastic... I'm sure had I gone with those I would be equally happy. Yet again I am just sharing my experience that I have been very happy with the performance of my easyservo setup, it's up to the individual to decide what features they particularly value.Last edited by Zeeflyboy; 29-03-2017 at 06:47 PM.
29-03-2017 #5
I'm assuming people are referring to these?
http://www.ebay.co.uk/itm/CNC-400W-D...8AAOSwsN9XCzyW
29-03-2017 #6
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
29-03-2017 #7
These servos look interesting (the SDSK models), price is around $250-$400 per motor, but interestingly they have built in drivers, so all they need is 75V Dc and Step & Dir signals.
https://www.teknic.com/products/clea.../clearpath-sd/
$319 (~£257) +postage gets you a 4.4nm nema 23 that still gives ~0.9Nm at 2500rpm !!
https://www.teknic.com/model-info/CPM-SDSK-2331S-RLN/
They have a USB port for diagnostics & tuning and have autotune software to run once installed on the machine.
I have no idea how effective the autotune is, or how good the motors are but they get generally good reviews on Youtube from our American "cousins".
I must admit to being interested, but at about £300 an axis (with postage, import duty etc), thats more than double an AM882+Nema 23 Stepper!Last edited by Greeny; 29-03-2017 at 07:58 PM.
29-03-2017 #8
29-03-2017 #9
If you paid £130 for genuine Leadshine closed loop inc delivery then you've bought very cheap. I've never seen any that cheap before or after brexit so well done.
We don't actually disagree too much, Closed loop are worth having over Standard steppers if only because of the 3phase 1.2 degree motors but only if there isn't great price difference. £80 or even £50 per axis is too much IMO
I've actually got 12 sets of closed loop on route to me which will be fitted to routers but this is only because they are larger motors and hardly any price difference between standard motors/drives.
CS-LAB AC-servos + SIMdrive
By blim in forum Stepper & Servo MotorsReplies: 0Last Post: 20-02-2017, 12:52 PM -
Mitsubushi Servos
By Chaz in forum General ElectronicsReplies: 0Last Post: 24-04-2016, 08:08 PM -
switching from steppers to servos - STEP / DIR control
By dsc in forum Stepper & Servo MotorsReplies: 6Last Post: 18-06-2014, 12:41 PM -
FOR SALE: Various Steppers, servos, drives for sale
By Peter. in forum Items For SaleReplies: 2Last Post: 02-02-2014, 09:56 PM -
Open Source Servos
By D.C. in forum Open Source Designs & PlansReplies: 0Last Post: 07-03-2013, 07:29 PM
