    Got a machine in for repair and it's fitted with one of Roy's System 3 board so looking for the PDF booklet on it if anyone has one.
    Can't ask Roy as he's retired to Spain and sold out to R-Tech, the welding people but they have discontinued all the CNC parts.
    John S -
    Now sorted, many thanks.
    John S -
    Hi John
    I have just had a look here -
    https://web-beta.archive.org/web/*/h...cnc.co.uk:80/*
    see next to bottom file
    found the system3 manual and a photo
    for some reason I cant upload the manual !!!
    I'l try and save the pages as jpegs
    John
ID:	21232Click image for larger version.
ID:	21233Click image for larger version.
ID:	21234Click image for larger version.
ID:	21235Click image for larger version.
ID:	21236Click image for larger version.
ID:	21237Click image for larger version.
ID:	21238Click image for larger version.
ID:	21239Click image for larger version.
ID:	21240Click image for larger version.
ID:	21241Click image for larger version.
ID:	21242Click image for larger version.
    John,
    Thanks for that but after doing a bit of searching earlier on the same site I determined it was a System 4 but with only three cards fitted.
    I now have about 5 copies of the various iterations of that System4 book.
    Many thanks anyway.
    Will have some more question is a fresh thread as this machine a Boxford 160 has a toolchanger fitted and it's been roughly converted to Mach3 [ one axis moves ] but it's lacking the tool changer macro.
    However I need to do some homework for myself first and then if still stuck, start a new thead.
    John S -
    Hi John
    good to see you have found the information you needed
    I've found the internet archive wayback machine use full several times when web sites I've searched for have closed
    my reply still use full if it brings the archive to the attention other members here
    John
    Hi John
    spindle 2 & pcpps circuits to add to your CRH Design archive
Name:	spindle 2 .jpg
    John
  7. The Following User Says Thank You to john swift For This Useful Post:
  1. RFQ: Semi automatic welding system Linear beam control system
    By richway in forum Projects, Jobs & Requests
    Last Post: 24-01-2017, 08:54 PM
  2. Breakout Board expandability...CNCdrive based control system
    By iforeman in forum General Electronics
    Last Post: 11-12-2016, 06:49 PM
  3. Setting up "System 45" 3 axis unit by DIYCNC
    By StevenT in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 03:22 PM
  4. Additional info System 4 DIYCNC
    By m.marino in forum Motor Drivers & Controllers
    Last Post: 15-02-2011, 02:04 PM
  5. Wiring in power and E-stop on DIYCNC Board
    By m.marino in forum General Electronics
    Last Post: 10-05-2009, 10:15 AM
