  1. #4
    Quote Originally Posted by JW1977 View Post
    Hej!
    Thank you, interesting to see!
    Hej igen!
    Thanks.
    The Leadshine DM2282 is a "mains" driver, ( 220V.)
    If I would have used the AM882, the stepper would have got about 75V.
    That’s a little more than the calculated max (66 V) but i guess it would have worked.
    With the DM2282 I get more margins and I won’t have to build another PSU so the cost will be about the same.
    I know it works because I can see it being recommended here and there but I can’t get what the output Volts will be?
    The way I interpret the manual of the DM2282 is that it can use DC or AC supply. The DC input range is 115~305VDC and the AC is 80~220VAC. It is NOT the mains you normally connect to the input directly, but through a transformer.
Name:	DM2282 connection.JPG
    I see two major reasons for this, one is personal safety, the other is that the mains in Europe is NOT 220V, so I would not connect it directly to the mains. Basically, if you want to build a PSU, that's fine, but regardless of which, you don't need it if you use the DM2282, you just need a transformer, but if you build one you can still use the DM2282 because it can use both DC and AC supply.
    Here is a link to the manual, in case you have not seen it yet:
    http://www.leadshine.com/UploadFile/Down/DM2282d_P.pdf
    My guess is that the output voltage will be (if using AC as supply): 1.41 x the AC supply voltage. If DC supply is used then the output will be the same as the input voltage if measured as I measured the voltage.
  1. Connecting 2.2kw vfd to Mains supply
    By the great waldo in forum Spindles & Drive Motors
    Last Post: 26-05-2016, 09:39 PM
  2. Mains power supply? How have you done it?
    By gary_808 in forum Gantry/Router Machines & Building
    Last Post: 01-02-2015, 04:45 PM
  3. HPGL driver output
    By 2006Nobull in forum Computer Software
    Last Post: 07-10-2012, 08:49 PM
  4. Mains, PSUs and other goodies.
    By Rogue in forum General Electronics
    Last Post: 28-08-2012, 12:37 PM
  5. 2M2280N High Voltage Stepper Driver
    By Robin Hewitt in forum Motor Drivers & Controllers
    Last Post: 14-11-2009, 08:43 AM
