Thread: DIY Pin Badge
    Wal, these are very nice and inspiring. What is it you fill them with and how deep are you milling them?
    Wal's Avatar
    I use cold enamel - like this:
    http://brightenamels.co.uk/documents...e%20(2016).pdf
    It's good stuff, but can be tricky to mix in small quantities, ie. 0.1gm colour + 1.9gm resin +1gm hardener. Too much/too little of one or the other and it doesn't set properly..!
    If I'm using >0.8mm cutters I'll cut to a depth of 0.75mm, anything under that I'll keep to around 0.5mm - in both cases it's probably too deep, but I get paranoid about belt sanding through the epoxy..!
    Wal.
  3. The Following 2 Users Say Thank You to Wal For This Useful Post:
    Did you check the job request for aluminum badge?
    Wal's Avatar
    Boyan - yep, I followed up on that but the job went no further (with me).
    Okay, last of the badge posts - as no doubt you get the idea. This one was made as a commission - a birthday present, I think... Two nicknames, two badges that can be worn or displayed together in a plinth. Smallest cuts here were with a 0.2mm - I could have got away with a 0.3mm, but the two I had both broke on the job and I had to re-program using the 0.2mm (which also eventually broke). Heh, I can see why people don't do these for a living - once you've taken materials/tools etc. into account, along with what this kind of job is 'worth' to the buyer, well, you're looking at less than minimum wage for this... but I guess as long as you're making on other work it's still enjoyable to do - trouble is you need to give 'em away at the end..!
    Has anyone got any tips for micro-diameter end-mills - I tend to cut slow and shallow, but am I better off going slower and cutting deeper, or do the same rules not apply at this scale..? I avoid using air with the small stuff and have found that covering the plate and then the channels being cut with WD40 tends to work better - sure, you'll need to remove the build up of tiny chips every once in a while, but they're so small they tend to float about and get pushed out of the way by the cutter. Here's a vid cutting the intermediate details with a 0.8mm cutter:
    Anyway, some pics - check out how the thin bit at the bottom of the second 'b' has survived - I didn't think it would make it past the 'clean-up with the old toothbrush' stage, but somehow it did... pretty cool.
ID:	21831 Click image for larger version.
ID:	21834 Click image for larger version.
ID:	21833 Click image for larger version.
ID:	21832 Click image for larger version.
    BTW, the best method for getting rid of air bubbles in the epoxy at this scale is, hands down, no bull, a waft of a blow-torch over the surface as was suggested on a previous post here. I didn't realise it would be so effective - they disappear instantly..!
    Wal.
  6. #5
    Hi Wal
    If you warm any laquer or epoxy it gets much runnier, the hardening process is also more thorough. But don't heat the epoxy until you've mixed it. I know an archery bow maker here who left her epoxy cans on a heating box she used to cure the resin and didn't notice until her bows started delaminating at a world champinship in South Africa. She had to fly out with replacement bows, expensive mistake!
    cheers
    Andrw
  7. #6
    Hi Wal,
    you have inspired me with your badges so i did something similar for a friend. Right now making a batch of 20. This was the test piece and has some minor flaws.
    Wal's Avatar
    Hey Boyan,
    That's pretty cool man. How did you get the textured/sand-cast effect in the black areas..?
