  1. #2
    If that's all you want to do, I doubt that you need more than an 800W spindle. After all, you could probably take a cut like that with a 600W hand-held router. I think a lot of us have spindles that are significantly over-powered for what we ask them to do, but in my own case that is purely because the usual 2.2KW spindle will take an ER20 collet which allows 1/2" shank cutters; if you don't need bigger than ER11 then I'm sure that the smaller spindle would be fine. However, incremental cost in going up a size is not that great, so might be worth doing to give a margin.
  2. The Following User Says Thank You to Neale For This Useful Post:
  1. Newbie - Help With Laser Cutting Speed And Power - 60W Laser
    By nickpscott in forum Laser Machines & Building
    Last Post: 11-11-2015, 10:07 PM
  2. redsail Laser Cutting Machine Cutter Engraving Engraver 500 x 700
    By sthdklen in forum Laser Machines & Building
    Last Post: 07-04-2015, 09:00 PM
  3. Replies: 5
    Last Post: 29-09-2014, 02:42 PM
  4. motor power and chinese spindles power HELP
    By DigiSoft in forum Spindles & Drive Motors
    Last Post: 17-09-2013, 12:17 AM
  5. Replies: 0
