Thread: 10 x 5 foot plasma table build
01-04-2017 #5
I have come up with a solution.
weld eggcup onto bottom of steel beam 1.
weld ball onto bottle jack.
fill eggcup with grease.
do this on 4 corners.
This is presuming that:
A.
The top surface of steel beam 1,
and the bottom surface of steel beam 2 are within a reasonable tolerance.
B.
The beams are straight. The shorter beams of the rectangle will have to be a very straight.
The weight of steel beam 2 will keep them orientated.
Now measure with spirit levels and adjust with bottle jacks. Repeat until correct.
When happy weld steel beam 3 into place.
Remove steel beam 1 as it was only ever a support.
New Build-12x6ft Plasma Table
By F1transportationserv in forum Plasma Table MachinesReplies: 23Last Post: 04-07-2015, 12:14 AM -
BUILD LOG: 4' x 4' plasma table build in Canada
By 190-v8 in forum DIY Plasma Build LogsReplies: 2Last Post: 02-02-2014, 01:19 AM -
By 190-v8 in forum Plasma Table MachinesReplies: 0Last Post: 29-01-2014, 12:27 AM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM
