    Hi everyone,
    Started routing a piece of plywood using UCCNC, with a cut that is uniform and parallel from end to end, to find that my Z axis is loosing position as it moves along the piece.
    The first time I was running constant velocity mode, with max acceptable error of 30 microns. I ran 95cm in length, the Z error was actually to push the Z axis into the piece further ( create a deeper cut ) , and over 95cm, I had a change in Z position of about 1 to 2mm deeper cut.
    The second time, I changed the constant velocity mode max error to 50 microns, decreased the Z axis max acceleration by 60%, and max speed to 30% to discount the motor missing steps due to load at higher speed/accelerations. This time the Z errors appeared to occur much faster, and after about 20cm, the Z had plunged down an extra 4.5mm.
    The G-code is correct, and I confirmed that without running the program, jumping from start to finish showed that the work was 4 to 5 mm deeper at one end vs the other.
    My thinking is that it somehow has something to do with Constant velocity mode ( although this is not supposed to create compound errors, just errors between point a and point c ) - or my controller not hacking it, or not providing enough holding power sometimes ( G540 )
    The wierd thing is, when I slowed down the z axis and accelerations, it got worse - which you would think would make better if it was a load related issue?
    Still wainting the leadshines to arrive, so need to persist with the G540 for now
    Any ideas?
    Nick
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Was the cut supposed to be uniform in Z (i.e. no Z movement along the cut) or was there some Z movement?
    Are you sure that the cutter is not being pulled out of the collet?
    So, the cutter is firmly in the collet. The part is uniform z from end to end, but across the part ( side to side ) there is z movement up in the middle, and down at each side. The CNN pass is parallel going across the part, move along by .5 mm, then across ... hundreds of times.
    If there is a lot of Z movement, and you are sure that the mechanical side of things is spot on, have you seen this thread?
    Thanks for pointing out that thread Neale -
    I found something funny happening to the Y axis in my UCCNC software, where my slaved axis was re-copying settings from another axis, including the wrong step and Dir information when I changed a specific value on one of the pages ( I'm not talking about the value of boxing slave, it's something else like if I make a change to the acceleration value, then the slave dumps all info and re-imports all info including the wrong pin and direction assignment ) . I still haven't figured out which value it is because I don't change the settings enough, but the randomly see my Y axis trying to go opposite directions as a result sometimes of me changing a few parameters.
    When I went back in to fix the issue ( not knowing why it had changed, or how ) in the confusion of trying to get my Y axis motors to spin in the right direction ( together ) - I Clicked on active low, so I had some dir / pin steps on active low, and some on active High for my X and for my Z axis.
    Guess where the errors were in my cut - in my z axis was the biggest, but X also had a left / right 1-2mm error by the end. So hopefully in a couple hours I can restart the beast up, and get my first workpiece cut out !
  1. mach3 csmio ips errors
    By Web Goblin in forum Artsoft Mach (3 & 4)
    Last Post: 07-01-2017, 10:47 PM
  2. Axis scaling errors - is this just to be expected with C7 screws?
    By GND in forum Gantry/Router Machines & Building
    Last Post: 23-11-2016, 11:19 PM
  3. Motorcalc spreadsheet errors
    By jimbo_cnc in forum General Discussion
    Last Post: 10-03-2015, 07:02 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
