Thread: Mysterious Z axis errors
31-03-2017 #8
I don't understand the question. In UCCNC you can select active high or active low for each outputs. Set active high for both the step and the direction pins in UCCNC ( i.e. uncheck the box )and you should be fine. Once set up right UCCNC will send step pulses as active high pulses. DIR pin does not actually matter since what is happening depends on how your motors are installed, so if the axis would rotate in the wrong direction if all the DIR pins are set to active high you just change that to active low. This is actually happening with my Y axis because the motor is placed where it is placed, so my X and Z are set to active high and the the Y to active low. UCCNC takes care of that.
mach3 csmio ips errors
By Web Goblin in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 07-01-2017, 10:47 PM -
Axis scaling errors - is this just to be expected with C7 screws?
By GND in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 23-11-2016, 11:19 PM -
Motorcalc spreadsheet errors
By jimbo_cnc in forum General DiscussionReplies: 7Last Post: 10-03-2015, 07:02 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
