    John,
    The cog looks similar but no, the video is a Gantry Job, it does vertical milling operations on the parts first with a Z axis you could park a Mini in, scale it down and it would look just like one of Jazz's routers, but maybe not quite as over-engineered as Jazz's stuff ;-)
    - Nick
    That was a serious machine ! (Unless it was a normal size machine with very small people running it?)
    The Z axis actually moved the whole gantry beam up and down, which although I've seen it done is unusual on DIY machines.
    I wonder what tolerance they can hold?
    Thanks for sharing Nick
    Quote Originally Posted by routercnck View Post
    If you watch closely the area above the tool whilst it's skimming the top and inside surfaces you can see that there is a Z with 1m to 2m travel which seems to be what they use for this job rather than movement of the whole gantry.
    - Nick
    Thats my megalomaniac dream come true.
    Nice one Boyan I knew you would post on this ! Some ideas for your next machine
  1. Beginner Moving Gantry Build? Read This!
    By Tenson in forum Gantry/Router Machines & Building
    Last Post: 23-05-2018, 05:30 PM
  2. BUILD LOG: "Henge", 3 Axis Cnc, Fixed Gantry, Moving Table
    Last Post: 20-03-2017, 08:43 PM
  3. Questions on using a moving gantry style mini-mill...
    By Davek0974 in forum Machine Discussion
    Last Post: 13-07-2016, 06:07 PM
  4. axis not moving when running code
    By geny in forum Computer Software
    Last Post: 21-10-2012, 08:02 PM
  5. Vertical moving gantry????
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 03-06-2009, 08:34 PM
