Thread: Cheap 3D Printer Recommendation
	01-04-2017 #1
I would like to get my Dad a small 3D printer. He doesn't have a need, it's just for fun and shouldn't cost more than £200.
I have a decent CNC mill/router and could cut part if there are easy to use files.
Can anyone recommended a good option? I was thinking kind of like maker bot wherd I cut the plywood parts and get a kit of the mechanisms. Though I guess maker bot is outdated now?
Thanks!Last edited by Tenson; 01-04-2017 at 04:31 PM.
	01-04-2017 #2
	02-04-2017 #3
I have the TEVO Tarantula I3 and it is great. Less than £200 shipped.
If you have the ability to make your own, check out the RepRap project.
Loads of builds on there ready to make.
	02-04-2017 #4
I have also acquired a Prusa i3 clone recently from Amazon (Hictop) and I highly recommend it as a starter, but from the experience of others who have bought similar printers I would recommend getting a model with auto bed leveling.
My CNC Projects: https://www.youtube.com/imadethisoncnc
	24-04-2017 #5
On facebook there is a group for Anet A8 3D printers, this printer cost about 150euros and it looks very good and solid.Unfortunatelly I do not own one and I cannot give more info.
The only disadvantage I can find is that it comes as a kit.
http://www.gearbest.com/3d-printers-...rvkaAoka8P8HAQLast edited by Nickhofen; 24-04-2017 at 04:36 PM.
	25-04-2017 #6
If you have a access to a milling machine/router that can handle the size of parts google I3 graber and make your own frame from aluminium or ply (The DXF files are open source and freely available) and buy everything else separately.
I am about to rebuild my Mendel to a I3 Graber so I can write you a list of parts and do a little build diary if you want.
I wouldn't expect to save money doing it yourself but I would expect the product to be far superior. Autolevelling is an inductive (Or capacitve sensor) cost me £1.50 to implement with a chinese special but sourced from UK still under £10.Last edited by Desertboy; 25-04-2017 at 03:52 PM.
	26-04-2017 #7
	26-04-2017 #8
No worries as soon as my frame comes I will strip it down and get pics then we can work from there.
	27-04-2017 #9
Plenty of open builds on Thingiverse:
https://www.thingiverse.com/thing:2254103https://emvioeng.com
The Following User Says Thank You to komatias For This Useful Post:
	27-04-2017 #10
To keep costs down though I would avoid extrusion after all this is a play thing not a production machine. I bought this frame from Ukraine (Still not arrived! after almost 4 weeks)
http://www.ebay.co.uk/itm/2821250171...%3AMEBIDX%3AIT
you can make this from 1/4 sheet of ply and I intend to remake it on my cnc milling machine when I finish it but oversized so I can print bigger, also make it with 12mm not 6mm ply which means minor cad modifications.
I was thinking though of modifying the cad files so I can bracket every corner then it will be on par with the aluminium machines but a damn site better looking ;)
I have a thing for wood especially when varnished.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
V-Groove Bit Recommendation?
By Tenson in forum General DiscussionReplies: 7Last Post: 05-02-2016, 04:42 PM -
Recommendation of Woodwork Shop to Hire?
By Tenson in forum General DiscussionReplies: 6Last Post: 31-08-2015, 02:27 AM -
Recommendation for getting MDF worked on in North London?
By surv1v0r in forum General DiscussionReplies: 0Last Post: 10-09-2014, 12:09 AM -
Spindle Motor Recommendation.
By cambesol in forum Marketplace DiscussionReplies: 0Last Post: 21-11-2013, 12:15 PM -
Router recommendation for University
By S2L in forum Marketplace DiscussionReplies: 12Last Post: 05-12-2012, 11:58 AM
