Thread: Cheap 3D Printer Recommendation
03-05-2017 #21
The Prusa MK2 mechanically made me laugh when i received it, but in reality it prints 24h non stop without a glitch. Its a well thought printer, but cheap to make printer. Its growling and making noise 10x as much as my CNC makes but it works and prints nicely. I could sit down and change that design to Hiwin rails, but thats their job to do, not mine, so i will not do it.
I dont know of a well thought printer thats mechanically sound. Maybe the Raise3d. What i dont like of that type of printers is that taking off the ready piece from the bed will do a lot of twisting and bending of all the frame and bed.
Again -- best deal for the money is the Steel Prusa from what i see around for cheap. Due to the quality components used. The electronics i mean.
03-05-2017 #22
03-05-2017 #23https://emvioeng.com
04-05-2017 #24
Agree with that. What i said was a simplification of the facts. Its handy to have a couple of top plates to change. Furthermore i remember somebody proved that the glass on top of aluminum is not a problem and will not lead to losses and cold spots. Still, if one forgets or learns,prints flat PETG part - could trash the glass. Also plate could be PEI, which will eliminate said problem, but will be more expensive to have a couple of them so thick.
05-05-2017 #25
I've ordered a kit from a UK supplier, it's a 6mm aluminium frame rather than acrylic so hopefully it should be at least a decent starting point :D
05-05-2017 #26
Nick, what kit have you ordered?
I'm in a similar situation. I'd like a 3D printer, as it would be handy for a few odds and ends, but I don't really have the time to research/build/learn/tweak a 3D printer.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
06-05-2017 #27
It's the one from Factory 3D in Newcastle-upon-Tyne ( http://factory3d.co.uk/ ). I'm sure there will be bits that I re-make, replace or re-engineer as I go along but I really like the idea of an aluminium main frame and a UK manufactured kit.
06-05-2017 #28
That looks like quite a good kit. It'll be good to see how you get on with it, and what you mod along the way.
07-05-2017 #29
I finally got my Graber I3 frame from Ukraine took about a month to arrive. I'm going to beef it up with metal corner brackets and modify it to take 8mm lead screws for the z axis instead of 5mm threaded bar.
Anyone with access to a cnc could easily make their own Prusa style frame from ply, mdf or aluminium.
I am upgrading a reprap mendal, will have to cut 4 of the smooth rods to fit. Not looking forward to cutting the stainless steel z axis rods.
I need to get an lcd for my ramps at some point but the cnc build is killing me financially so it can wait it's no hassle to print from my laptop.
One thing if using windows you have to make sure automatic updates are off, power saving and anything that might put the pc to sleep or reboot it must be disabled. In Linux this is not so much an issue but you can configure a windows pc fine. I use a windows pc for timelapse that's been on for months with no issues.
I'm going to plug the printer into a 1kw UPS (Just because I have one spare) so will have a little extra protection but not essential.Last edited by Desertboy; 07-05-2017 at 01:24 AM.
07-05-2017 #30
Would you be better with more traditional methods for a wood frame?
Wood corner braces bonded in place with Cascamite, or even Gorilla Glue might provide more rigid triangulation over a larger area than metal brackets.
Pinned and glued is almost always superior to metal brackets and bolts and screws with structural wood projects.
The Following User Says Thank You to magicniner For This Useful Post:
V-Groove Bit Recommendation?
By Tenson in forum General DiscussionReplies: 7Last Post: 05-02-2016, 04:42 PM -
Recommendation of Woodwork Shop to Hire?
By Tenson in forum General DiscussionReplies: 6Last Post: 31-08-2015, 02:27 AM -
Recommendation for getting MDF worked on in North London?
By surv1v0r in forum General DiscussionReplies: 0Last Post: 10-09-2014, 12:09 AM -
Spindle Motor Recommendation.
By cambesol in forum Marketplace DiscussionReplies: 0Last Post: 21-11-2013, 12:15 PM -
Router recommendation for University
By S2L in forum Marketplace DiscussionReplies: 12Last Post: 05-12-2012, 11:58 AM
