I was thinking a small capacitor across the input terminals, but a electrolytic may not be good enough if it's a high frequency noise/harmonic problem. However it would be a simple thing to try if you have a small electrolytic capacitor about.
The best thing would be to put a scope over the input terminals to see if it is a noise problem, as without seeing what's going on, it's pure guesswork.
Doesn't UCNC support Modbus?Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
14-04-2017 #2
Thanks for the response.
No, I don't have a scope, or an capacitors either.
It's actually probably good enough for a wood router, but I'll have to wait until I can cut something to know for sure.
I was really just wondering if anyone else has tried controlling these with an analog signal? I'm curious if all of these Huanyang VFD's suffer from this issue?
I found one other post with the same issue on the Mach3 forum, but it had no replies.
These Huanyang VFD's use a non standard modbus implementation, so you can't control them with Modbus. But someone did write a UCCNC plugin, that supposedly works very well.
Since my breakout board has the speed control already there, I set it up that way first.
I'll be ordering an RS485 converter, and testing with the plugin when it comes in.
Thanks again.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
16-04-2017 #3
Gerry, I've fitted well over 100 Huanyang VFD's using analog and while do get some flutter it's nothing like what you are seeing. I'd be inclined to think like MC that it's noise issue so check cabling etc.
16-04-2017 #4
Thanks Dean, that's the info I was looking for.
I don't have any shielded cable handy right now. But I did make up a new spindle cable with twisted wires (It's only 12" long), and I grounded the spindle, as it wasn't grounded in the video. But it didn't make any difference.
It just seems to me that I'd see a change in the analog voltage, with a 25-30Hz swing in the frequency?
Since this is just a test, I'll revisit it later when I actually build the control box.
I've got an RS485 converter being delivered today, and will try the UCCNC Huanyang "modbus" plugin. It only cost me $7.Gerry
16-04-2017 #5
I just tested with the UCCNC plugin, and speed control with that method is perfect.
I guess that there's not really any downside to using the plugin/modbus, as the cost is only $7?
https://youtu.be/jmdV3Y_ffyoLast edited by Ger21; 16-04-2017 at 05:21 PM.
Gerry
16-04-2017 #6
op-amp to drive +/-10V analog servo from old +/-5V controller
By paulus.v in forum Motor Drivers & ControllersReplies: 21Last Post: 14-02-2017, 08:33 PM -
Advice please : Quick voltage and amps question + speed control
By Fivetide in forum Motor Drivers & ControllersReplies: 21Last Post: 06-12-2016, 12:55 AM -
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
Controlling the spindle RPM
By D-man in forum Spindles & Drive MotorsReplies: 16Last Post: 28-04-2016, 08:20 PM -
Huanyang VFD control plugin for Mach3, USB RS-485
By JayPunchbuggy in forum Spindles & Drive MotorsReplies: 19Last Post: 15-05-2013, 08:00 PM
