14-04-2017 #6
Thanks for the response.
No, I don't have a scope, or an capacitors either.
It's actually probably good enough for a wood router, but I'll have to wait until I can cut something to know for sure.
I was really just wondering if anyone else has tried controlling these with an analog signal? I'm curious if all of these Huanyang VFD's suffer from this issue?
I found one other post with the same issue on the Mach3 forum, but it had no replies.
These Huanyang VFD's use a non standard modbus implementation, so you can't control them with Modbus. But someone did write a UCCNC plugin, that supposedly works very well.
Since my breakout board has the speed control already there, I set it up that way first.
I'll be ordering an RS485 converter, and testing with the plugin when it comes in.
Thanks again.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
op-amp to drive +/-10V analog servo from old +/-5V controller
By paulus.v in forum Motor Drivers & ControllersReplies: 21Last Post: 14-02-2017, 08:33 PM -
Advice please : Quick voltage and amps question + speed control
By Fivetide in forum Motor Drivers & ControllersReplies: 21Last Post: 06-12-2016, 12:55 AM -
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
Controlling the spindle RPM
By D-man in forum Spindles & Drive MotorsReplies: 16Last Post: 28-04-2016, 08:20 PM -
Huanyang VFD control plugin for Mach3, USB RS-485
By JayPunchbuggy in forum Spindles & Drive MotorsReplies: 19Last Post: 15-05-2013, 08:00 PM
